Removing the Powermate body
14 replies to this topic
#1 thecelloronin
thecelloronin
  • Loc: Lowcountry, SC
Posted 16 April 2024 - 11:24 PM
I read this thread about how it’s possible to remove the 2X Powermate’s body and attach it to things with a T2 adapater.
https://www.cloudyni...w/#entry3971419
However, I’m confused as to why this poster says the power of the powermate is 1.6x. I thought the whole charm of these telecentric designs is that it doesn’t matter where you place it along the optical train, they stay parafocal and don’t change powers like a barlow.
Am I out to lunch here?
#2 MisterDan
MisterDan
  • Loc: Colorado
Posted 16 April 2024 - 11:39 PM
The magnification variance (with distance) with the 2x Powermate is - according to this chart - effectively nil.  Other Powermates do indeed vary.
https://www.televue....?id=53&Tab=_app
I can't speak to the 1.6x claim, unless that is based on typical Barlow variance (with distance), which don't apply to the Powermates.
Best wishes and kind regards.
Dan
  • thecelloronin likes this
#3 betacygni
betacygni
Posted 17 April 2024 - 12:56 AM
Think the poster in that thread was simply wrong. Powermates change very little in power with distance changes (except the 5x powermate it seems), at least relative to barlows which change a lot.
  • CrazyPanda and thecelloronin like this
#4 Starman1
Starman1
    Stargeezer
  • Loc: Los Angeles
Posted 17 April 2024 - 08:48 AM
Tele Vue makes T2 adapters for all of their PowerMates, whether 1.25" (2.5x and 5x) or 2" (2x and 4x)
There is no 1.6x PowerMate.
  • simon99 likes this
#5 Doug Culbertson
Doug Culbertson
  • Loc: N. Florida
Posted 17 April 2024 - 08:57 AM
He is talkiing about attaching the Powermate with T-2 ring directly to the end of a binoviewer; specifically a Baader Mark V binoviewer. When attached directly to a binoviewer in this manner the Powermate acts at a slightly lower power. This is due to the light path of the binoviewer. For example, when I attach my 2.5x Powermate to my CZAS binoviewer it works at somewhere around 2.1x. This has been verified several times in the binoviewers forum.
#6 Starman1
Starman1
    Stargeezer
  • Loc: Los Angeles
Posted 17 April 2024 - 09:04 AM
How is that possible?  Does the binoviewer act like a focal reducer?
#7 Doug Culbertson
Doug Culbertson
  • Loc: N. Florida
Posted 17 April 2024 - 09:22 AM
Sorry, I'm lousy at math so I can't explain it. Something to do with the long light path of the binoviewer. I do know this, I directly compared the TV 2x BV corrector to the 2.5x Powermate in my former Baader Maxbright II  binoviewer and it was virtually identical in magnification and fov. Drift timing with my current CZAS binoviewer and a pair of 24mm Brandons shows it to be right around 2x, perhaps a bit more, but not 2.5x.
Go browse through the binoviewer forum. Eddgie is the one who alerted me to this fact, and he can explain it much better than my rudimentary understaning of it.
As I said, there have been several mentions of this in the Binoviewers forum
https://www.cloudyni...kay/?p=13168220
https://www.cloudyni...ase/?p=13267093
https://www.cloudyni...ets/?p=13184622
Edit to remove double link.
Edited by Doug Culbertson, 17 April 2024 - 09:33 AM.
  • betacygni likes this
#8 betacygni
betacygni
Posted 17 April 2024 - 10:12 AM
If you check the Televue chart linked in a prior post the 2.5x Powermate has a reduction in power as the distance between it and the eyepiece increases. Binoviewers obviously make this distance substantial. That said I have no idea why the 2.5x powermate has this behavior, it appears to be the only powermate that reduces with distance, the others increase to various degrees.
  • Starman1 and Thomas_M44 like this
#9 thecelloronin
thecelloronin
Posted 21 April 2024 - 12:55 AM
does this mean that the 2.5x 1.25" PM also unscrews from its body?
#10 Starman1
Starman1
    Stargeezer
  • Loc: Los Angeles
Posted 21 April 2024 - 01:17 AM
https://www.televue....id=53&Tab=_back
Yes, it separates at the line above the 2.5x lettering.
The T-adapter threads on there.
#11 Doug Culbertson
Doug Culbertson
  • Loc: N. Florida
Posted 21 April 2024 - 11:37 AM
Parts separated and lower part with T2 ring.
#12 Doug Culbertson
Doug Culbertson
  • Loc: N. Florida
Posted 21 April 2024 - 11:40 AM
2.5x PM attached to my CZAS binoviewer using the T2 ring.
Edited by Doug Culbertson, 21 April 2024 - 11:40 AM.
#13 junomike
junomike
  • Loc: Ontario
Posted 21 April 2024 - 03:17 PM
As I recall some earlier Powermates aren't compatible with the T2 Ring as the  separation was between the body and chrome barrel (as opposed to newer one's that separate between the body housing).
Non compatible older style
Compatible newer style
  • Starman1 and Doug Culbertson like this
#14 betacygni
betacygni
Posted 21 April 2024 - 03:18 PM
Have you ever tested how close the 2.5x powermate makes the CZAS being parfocal to a mono eyepiece?Have been very curious but haven’t went the route of buying one to find out.
I have the uncomfirmed theory that a standard glasspath would introduce prism aberrations in a mirrored binoviewer that they are designed to correct in a prism model, which would make the 2.5x powermate the best CZAS option. But some of my scopes are back focus challenged and need nearly full light path compensation as compared to mono.
Edited by betacygni, 21 April 2024 - 03:24 PM.
#15 Doug Culbertson
Doug Culbertson
  • Loc: N. Florida
Posted 21 April 2024 - 04:03 PM
You know, I have not tried that. For some reason, it never entered my mind to compare it to a mono eyepiece, though I suspect that it would not be parfocal with eyepieces in a binoviewer even with a PM.
I have the same unconfirmed theory as you regarding a GPC in a mirror based binoviewer. I've mentioned that a couple of times in the Binoviewers forum, but nobody has confirmed or denied it. When I bought this binoviewer from Denis I asked about a GPC and he said that he would not use one, but didn't elaborate.
