Recently, our astronomy club was gifted a 10" LX200 GPS as a donation. The donor had told me that he couldn't get it to work anymore, but we figured we could at least try to figure out what was wrong with it, perhaps flash the firmware, and, in the worst case, defork the OTA.
I got the telescope home, plugged in the AC adapter and Autostar II handbox, and turned on the power. Immediately, I noticed the Autostar just started displaying red boxes/squares on the display, one at a time until it fills the screen, but no text. I turned the power off and back on a few times to see if this was an anomaly, but it did the same thing. I left the system on for an hour to see if any change might occur, but the results were still the same (a string of red squares/boxes on the Autostar II display screen).
I then tried seeing if I could go into download mode by hitting "999" as soon as power was turned on, but all that did was either stop the squares from showing up or caused other strange characters to appear on the screen (the most common was a lowercase x with a line above it). I tried connecting via a laptop with StarPatch to see if I could flash the telescope with another firmware (laptop-->USB-to-serial connector-->Meade 507 cable-->left RS232 port on telescope base, a setup I've used several times with my own 12" LX200 GPS), but the software cannot connect to the telescope through the COM port. Also, the telescope does not respond to any other commands to slew in any direction,
At this point, I was hoping the community might have some other suggestions. My guess is that there is an issue with the main board, but it's just a guess at this point. Has anyone seen this issue before and found a solution to the problem? TIA.
Image attached of the handbox and the display.
Joe
Edited by jkhalaf, 17 April 2024 - 11:07 AM.
