I suspect this is not right.
Turned on scope to verify setup before breaking it down for an outreach event. Saw led come on, oops Autostar II no plugged in. Turned off, plugged in ASII, turned back on, nuttin. Took off front panel and found this. Any idea what caused this? Do you think it took out anything else? Did R34 sacrifice itself for the good of the mainboard? Maybe I need a 2 amp fuse for the scope drive separate from the cameras and usb hub?
