Hello, I was able to photograph a little bit of this recent total solar eclipse. I am still a little new to astrophotography, so this was my first attempt in photographing the solar eclipse, and I wasn't able to fully prepare for everything, but it turned out fine. However, my issue is there were some technical difficulties that messed up my timing for the exposure times from doing diamond ring and bailey's beads, (and I was mostly focused on enjoying the actual eclipse) resulting in underexposed images of totality. And I changed the right totality settings too late when clouds started covering it up, and I tried increasing the exposure and it appeared I also did that too late as it was already in the second bailey's beads stage. I took these in burst mode, so I have about 100 photos throughout totality. My question is, is there still a way I can turn these underexposed images of totality and turn them into a more exposed or detailed image? (I'll have to center them). Here are a couple I took:
https://drive.google...iew?usp=sharing
Edited by Diamond_Enderman, 17 April 2024 - 05:07 PM.
