Adding OAG to my current rig
#1
Posted 17 April 2024 - 05:34 PM
#2
Posted 17 April 2024 - 06:23 PM
My understanding was that Canon DSLRs have a distance from flange to sensor of 44mm, so unless your OAG is 11mm thick, it is going to push the sensor too far back.
#3
Posted 17 April 2024 - 08:03 PM
#4
Posted 17 April 2024 - 08:48 PM
Why add an OAG to this rig? There's no need for a 61mm OTA. I run an OAG on my RedCat51 and it works well enough, but the only reason I do this is the optical train is bolted together and I move it between OTAs.
- Oort Cloud likes this
#5
Posted 17 April 2024 - 11:41 PM
- DeepSky Di and Oort Cloud like this
#6
Posted 18 April 2024 - 04:54 AM
"Thin" OAGs designed to fit directly to a DSLR, such as the Orion and Teleskop-Service 9mm, do work, I have the TS one.
- jwestervelt likes this
#7
Posted 18 April 2024 - 03:11 PM
#8
Posted 18 April 2024 - 10:42 PM
Due to illness, I need to minimize the number of pieces I need to unassemble/assemble in the field, especially in the dark, if I want to remain in the hobby, which I do. It would be extremely useful for me to get my guide camera off of the OTA in into the image path. I hope this explains why I'm looking for a OTA solution.
Whether it's an OAG or a guide scope, I leave it on the OTA. I wheel one rig out on wheely bars and move the other one in the car. Maybe there's some alternative to tearing down ? Best wishes.
#9
Posted 18 April 2024 - 11:27 PM
It sounds as if he wishes to do what I do. I have my imaging unit which has my OAG, filterwheel, and imaging camera assembled and set up so that the backfocus is correct on my refractor and the cameras are aligned to either the RA or DEC axis. For my reflectors, backfocus isn't a concern, so I just unscrew the OAG from my refractor's M54 thread, screw on a 2" nosepiece, and ram that into one of my reflectors as needed.
I velcro'd my slim 7port USB3 hub to my filterwheel, and that provides me with a single cable connection back to my laptop. There is a single USB serial connection going from my imaging unit to the mount's RS232 port. I can just store the whole thing, USB cables and all, in one of my pelican cases and not have to worry about doing a lot of setup whenever it comes time to go out for an imaging session.
#10
Posted 18 April 2024 - 11:32 PM
#11
Posted 19 April 2024 - 10:03 AM
For my Z61 I just leave the guidescope and guide camera on. -and sometimes even leave that on if I use my mono camera rig that has an OAG on it.
I keep the OTA assembled when traveling too. I just use a hard shelled storage case with foam to keep things safe and from moving around. . -no messing with stuff. I don't need to mess with the guide camera setup at all and never take it off.
But yeah an OAG is overkill, and almost a guidescope combo too depending on your exposure and mount. One time I forgot to guide on my CGEMII and didn't even really notice anything different in the sub exposures.
If you have issues with knurled knobs, I'd replace them with wing bolts if you have the room. If not get longer wing bolts for extra clearance. Maybe even replace them with allen bolts and use a wrench or large T handle.
z61 with guidescope/camera
wing bolt
T handle allen
- ah.clem likes this
