Hey all, question for the experts. Hope it's an easy one.
Last year, I made the move from an Apertura 10" reflector to a used 9.25 SCT because I wanted to be able to use a go-to mount. I did lots of lucky imaging using an equatorial platform with the 10" and I learned how to collimate the reflector while recognizing the signs of not having that done. While I've had reflectors for decades, this is my first SCT.
Some of my images with the SCT have double vision artifacts that almost leave me cross eyed. I've seen the same effect on some of the images posted in this forum but not sure what causes it and how to fix it.
Is it a matter of collimating the SCT and dialing in the secondary mirror? Or is it a processing artifact and the images aren't being stacked properly? Or am I seeing issues at the edge of the field of view that can't be helped? It seems to have a double image throughout the entire image. I want to say the more I sharpen the worse it gets, but I still see detail, just double.
I'm using the same imaging processing that I was using before. Sometimes ordering by quality in PIPP, stacking using AutoStakkert then sharpening using RegiStax6 followed by final tweaks in PhotoShop.
I've attached some images below of what I'm seeing. The bright mountain tops have a secondary image that outlines the bright spots. The Hadley Rille looks double.
Thanks in advance and I really enjoy seeing everyone's images here!
