Tonight I tested each pair of ep's I had on the moon. I was looking to see what was good, bad, sellable and worth keeping. It was a great time. I was using my SVX127D and Denkmeier Super 27 set. I had the OCS in as one section of removal tube was too tight and I didn't have my strap wrench handy to remove it safely. I had finally found a block of time to compare a few sets of eyepieces I had bought over the last year or so. This is by no means a scientific study filled with facts and numbers, it is a from the hip reaction from a lay observer using the set up described.
So I tried:
Edmund Optics RKE 12mm.
I felt like I was looking thru a straw. Dark. I will not use these again.
Matsuyama 10mm 85º
Very tight eye relief for me, had to almost touch eyelashes to glass. Brighter than the Edmunds and also like looking thru a slightly larger straw than the Edmunds but not by much. Will not use again.
Televue 19mm Panoptic
Holy Moly!!! My vision was filled with the moon, I could see the edge of visibility if I looked but why look of that? The brightness, contrast, color and sharpness were excellent. I will keep these and search for other EP's that offer similar views if possible.
Astro-Tech 9mm XWA
These were too big to be able to see through both. I cannot binoview with these and will sell one or both. When I did focus with one eye the view was nice and sharp, not quite as bright as the 19Pan.
Televue 7mm Delites
Also large eye tubes? covers? and difficult to get a single image otherwise excellent in color, brightness etc. I could decloak, I have read others have done this with success. My eyes may be too close together, far as I know my IPD is 59-61mm, thin but not outside the specs of these binoviewers as far as I know.
Denkmeier 14mm matched set.
Very bright, very sharp. Slightly less contrast than 19Pans. A bit harder to find image than with the 19Pans also but not by much. These are great eyepieces as far as I am concerned.
So I am left with a pair of 19Panoptics that are utterly fantastic to use in the Denkmeier Super 27's. My ultimate question to others with more knowledge and experience than I is, which eyepieces give similar views as the 19 Panoptics? Should I look at specs and buy similar or is there a shortcut one can use? Any and all replies are greatly appreciated!!
