Thanks, Achernar, 12BH7, and Tom.
Tom; yes, I am still using blind deconvolution. It's like any other sharpening method in that it produces better results with better data and more of it. When the seeing is good and I am able to stack thousands of frames, the results are better than when the seeing is poor and I can only stack a few hundred frames. It's no fault of David's software. Any misuse is entirely my own. :O)
Regarding denoise, I try to avoid it on lunar images unless absolutely required by being forced to stack too few frames for an image. I will always take noise for sharpness, even if it is only the appearance of sharpness due to noise. ;O) This is particularly so because I am only sharpening luminance these days, which does not bring up color noise, and luminance noise at the pixel level gives the image a grittiness or texture that I like. There was no denoise used on this image at all.
Edited by Borodog, 20 April 2024 - 10:41 PM.
