I made sure this thing was clean of smudges and dust spots. For some reason after DBE in PixInsight, It looks like this. What the heck could be wrong?
Posted 21 April 2024 - 10:33 PM
Did you take flats?
Did you take flats?
No, I did not yet. This is some test data.
Posted 21 April 2024 - 10:35 PM
Well, flats will fix that, so don't worry.
Posted 21 April 2024 - 10:37 PM
Will they fix the wavy vertical banding too? Or just the dust spots?
Posted 21 April 2024 - 11:11 PM
Did you take any calibration pics? Is this one sub or a stacked sub? If it's stacked what are the details? Also, what are the details on a sub?
Posted 21 April 2024 - 11:13 PM
Flats will fix the dust spots but they may not fix the wavy vertical banding. It depends on the cause of the wavy banding. For instance, my Sony A7S had green/purple vertical swathes that I was never able to calibrate. Believe me, I tried everything.
Posted 22 April 2024 - 12:23 AM
Posted 22 April 2024 - 08:07 AM
After Flats it still has issues:
But they weren't taken or applied correctly or else you wouldn't see the dust motes. Did you take bias?
Again, is this a stack or a sub? What's the details?
Posted 22 April 2024 - 08:11 AM
Posted 22 April 2024 - 08:17 AM
This was 600 30sec subs and I took the flats outside using a clear sunny sky and used 1/160 shutter for that, same for the dark flats and all at ISO 400. Stacked in Deep Sky stacker
You mean in the middle of the day? I never do sky flats, but I think everyone takes them at dusk or in the morning. Is the striping in a single sub?
Posted 22 April 2024 - 08:26 AM
Posted 22 April 2024 - 08:59 AM
You need to be focused at infinity, and put something like a t shirt over the lens. Mid day in the sun 1/160 sounds way too long for a flat. The histogram should ideally be in the center, or just left if it.
Brian
The focus should be close to infinity, but it should be exactly the same focus as the lights.
Posted 22 April 2024 - 08:04 PM
Brian
I did but still get the same kinda thing.
Posted 22 April 2024 - 08:31 PM
If the canon banding script doesn't clean them up, as another reply indicated. Sirill also has a script that is very good at correcting that type of banding. Sirill is free. Also, the GradiantCorrection process in Pixinsight cleans up a lot of my banding. I image with an old Canon, so I have to clean up banding all the time.
So, do your calibration frames. Process in WBPP with everything, see if the banding is still bad. And run the gradiantcorrection process. If still have banding, run the canon banding script in pixinsight. If still something left, then download Sirill and run it's banding script. You will be surprised at the results.
Dan
Edited by DanMiller, 22 April 2024 - 08:35 PM.
Posted 06 December 2024 - 11:27 AM
Posted 06 December 2024 - 02:11 PM
Were you able to resolve the issue?
You could refer to this as well:
https://www.markshel...d_polygons.html
According to https://www.markshel...ra_summary.html , Sony A7IV doesn't have "coloured polygons" issue.
Posted 06 December 2024 - 02:59 PM
Great. Thanks for pointing this out.According to https://www.markshel...ra_summary.html , Sony A7IV doesn't have "coloured polygons" issue.
Edited by caspase888, 06 December 2024 - 02:59 PM.
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
