In keeping with my intended theme of big eye lenses, immersive viewing and reasonably wide FOVs, this is the last piece of the puzzle. I have a 12.5 , 17.5 Morpheus, and will be getting the rest except the 14, and I need a 3.5mm extension to the regime.
How does the Delos compare to the XW? My scopes are a 12" F/4.4, and 8" F/6, both dobs. I was considering a 3.5 Nagler, but scratched that as research has told me that the Delos has better transmission and may be sharper. And ofcourse, there is the immersion factor. Big eye lens. The XW, has 2* smaller FOV (yes, that bothers me), is about 90g lighter, and significantly cheaper. How does it compare to the Delos in terms of transmission, edge performance, and all round comfort? Never used either. For reference, I use Delites, the two aforementioned Morpheus focal lengths, and a 26T5 Nagler. At this F/L, my main targets would be Lunar, globulars, planetary nebulae, and small faint galaxies. How would either of these fit in with a set of Morpheus, 2.5 and 5x Powemates, and a possible 3x barlow (which I am also considering, to fill in some gaps).
So, basically, at the end of the day, shall I get the turkey leg, or get the slightly less plump turkey leg?
Edited by HellsKitchen, 01 May 2024 - 08:24 AM.
