Well, if we have a look at wikipedia, there are about 200 photometric systems in use in past and now.
Coming back on this T Crb topic, how to operate?
Filters:
the system in use visually seems to be with the use of johnson filters UBVRI (defined histotically for visual measurements).
Buying the set of recognised filters, it costs more or less 1000 usd.
We may use color filters, cheaper when following the BAA paper based on tests.
Here is:
https://britastro.or...VRI_filters.pdf
where a W38 and a 400-700 filters is similar to a U bessel filter; a W56 and a W12 similar to the V bessel filter, etc...
A calibration is needed to match with the ccd chipset in use.
Procedure to be used, given through the paper of the AAVSO
https://www.aavso.or...Manual_v1-2.pdf
These are general ideas. Now for T Crb, with the hardware to be used.
How with a dslr, already for other bodies,
How with the ss50 equipped with a 462C, with a tele and any other chipset
conditions needs to be settled prior to operate to keep confidence in the results.
Commencing the debate, the discussions?
Nothing more yesterday 31st july 20H30 UT.
Good skies.
Stanislas-Jean
