Thank you this was helpful… glad it just complains about temp instead of refusing to use them
I put the D3 out last night to let it cool down. I then installed the solar filter, put it in the shed, and closed the door. I took a bunch of darks at various exposures and gain. Problem is, by the time I started imaging the temperature had dropped even more and the D3 complained that the darks were off by more than 8 degrees. I used them anyway. Didn't want to wait.
The D3 selects the darks based on the exposure and gain that you select. If it doesn't have any darks at that exposure and gain it will ask you to make some. If it does have darks at that exposure and gain, but it's off by more than 8 degrees, it will complain. To delete a dark you have to long press on a dark, check the darks you want to delete, and then hit Delete. Weird thing is that it won't let you check some of the darks. Don't know why yet.
