DWARF 3, new smart telescope confirmed!
1578 replies to this topic
#1551 bkushner
bkushner
  • Loc: Haddon Township New Jersey
Posted 14 May 2025 - 09:58 PM
BH Just sent my unit ordered in February.  Going to immediately sell it new in box. No longer wanted.
Edited by bkushner, 14 May 2025 - 09:58 PM.
#1552 Starlancer
Starlancer
Posted 21 May 2025 - 02:19 PM
Just a heads up - B&H in the US has them in stock to buy (At least 1)
#1553 Trick
Trick
  • Loc: UK
Posted 24 May 2025 - 02:36 PM
Took me two weeks from order to delivery this month.
#1554 Finfid
Finfid
  • Loc: 38.66922076097237, -122.63357689749888
Posted 31 May 2025 - 03:47 PM
I ordered the Dwarf 3 from B&H as well. Came in two days. I WAS very excited. After the first night though, I'm very sad and disappointed. The design, tech, app and interface are all so very, well primitive but unnecessarily complicated. I have an Seestar S30, that thing was ready to go out of the box. The Dwarf requires A LOT of tweaking and the learning curve is much higher. There are too many variables with the Dwarf just to get it up and running for any kind of shoot. My Celestron is easier to setup and I have to manually align that thing every time I use it.
Still on the fence about keeping this thing. For the money I feel you don't get enough value.
My advice, is to try before you buy if you can. If you want to get into the Smart Telescope hobby, I have to recommend a Seestar S30 or 50 as a first device. Cheaper and sooooooooooooooooooooooooooooooooooooooo much easier.
Edited by Finfid, 31 May 2025 - 03:47 PM.
  • Stevan Klaas likes this
#1555 Tsb1948
Tsb1948
  • Loc: Douglassvile,Pa
Posted 31 May 2025 - 04:13 PM
I find it comparable to flying a drone or using an action camera. There is a learning curve but it's not that steep.
#1556 Infiniumguy
Infiniumguy
  • Loc: Colorado Springs, Colorado
Posted 01 June 2025 - 07:25 AM
My first smart telescope was a Dwarf 3. It did take some time to learn how to operate it. Like you I found the app unnecessarily complex and at times pretty frustrating. I was successful using EQ mode and getting some images I was happy with. After several months and a lot of reading I sold it and bought a Vaonis Vespera 2. Confirms you get what you pay for. My frustration level went down dramatically and my enjoyment went up dramatically. The V2 just works and the app is superb. Good luck.
  • Boki, Finfid and BrickInTheSky like this
#1557 Starlancer
Starlancer
Posted 02 June 2025 - 12:30 PM
Hmm, I didn't find the app that confusing, there are some guides that are included with the app, I suggest checking them out as I learned a couple things from it.
I will say that's why of the reasons I find the dwarf more appealing as there are more settings and I often find my Seestar more limiting.  I did notice there is an auto setting now for exposure, gain, etc. I haven't tried it since I set things manually.
I still have one gripe with the app, when I enter the atlas to find a new target, the location when entering the app should be the current location you are observing, instead of a random spot somewhere in the sky (Seems to be always very low to the horizon)
May be they need an advanced mode and simple mode setting.
  • oneuke, Skywatcher_neb, Tsb1948 and 1 other like this
#1558 pfile
pfile
Posted 04 June 2025 - 11:57 AM
some questions - tried to find the answers in the thread but couldn't find the answers:
sounds like you can get access to the raw data including bias, darks and flats. where do the flats come from? does the telescope automatically take dawn/dusk flats? or do you just have to do this yourself with a flat panel or something?
i didn't see any widefield images in this thread - can you do all the same astrophotographic work seen in the long FL images with the short FL lens?
can you polar align one of these w/o being able to see polaris? iow does it support drift alignment or 3-star alignment like polemaster or the nina polar alignment plugin?
i guess it doesn't do any guiding at all so good PA is a must?
does the automatic scheduling actually work? or is that a planned feature?
thanks
rob
#1559 Skywatcher_neb
Skywatcher_neb
  • Loc: Omaha, Ne
Posted 04 June 2025 - 02:56 PM
I can answer a couple of those questions. Very easy to polar align with very little view of the sky. I rarely have a view of Polaris. I use the scheduling feature almost exclusively.  Make a schedule anytime during the day, align the scope as soon as it gets dark enough to see a couple stars and focus. Sync the schedule and go to bed.
  • oneuke, pfile, vineyard and 1 other like this
#1560 LeeB.
LeeB.
Posted 05 June 2025 - 10:55 PM
thanks
rob
A master flat is included in the calibration folder for both telephoto and wide angle cameras. Darks are also included from the factory, or you an take your own there's a feature in the app that lets you do that. Presumably you could use the schedule feature to take sky flats. I've only used the included flat, for now.
Just a quick side note... It seems that the fits files loaded to the camera are automatically dark subtracted. For calibration in Pixinsight I only use the master flat (I'd be curious if others have a differing opinion on that point).
So far I've mainly used the wide angle camera for taking pictures of constellations. Here's a compressed image:
It's about 2-3 hrs, 30 sec exposures, I had to rely on blurxterminator to fix the stars in the corners and noisexterminator. Scorpius is low on the horizon where I live so I had to tinker with the WBPP setting to remove as much of the trees as possible.
It does a 3 point alignment, and gives you instruction for how much you should adjust the tripod / mount. However I will say that I noticed quite a bit of star trailing with that method. I have a Star Adventurer with a polar scope, so I use that for polar alignment now (I still let the dwarf do all the go to and tracking). I've seen much better results so far.
It does seem to have the ability to guide. When you give it go to instructions it automatically picks a star in the center of the image, goes to it, and tracks it. I've seen others post that it will dither, but I haven't noticed that. When I blink through my images I don't see any significant shifting between frames, and I get the classic walking noise in my stacked images.
I haven't used the scheduler so I can't help with that.
Edit: Yes, the wide field camera has all the same features as the telephoto. GoTo, auto focus, tracking, ect.
Edited by LeeB., 05 June 2025 - 11:00 PM.
  • Skywatcher_neb, pfile, Peter Besenbruch and 2 others like this
#1561 vineyard
vineyard
  • Loc: London
Posted 08 June 2025 - 05:20 AM
I've used the scheduler and after one glitch the first night, so far it seems to work fine.  You have to allow at least 10 minutes before the scheduled job begins, and if you're doing multiple jobs then allow for about 20 minutes between jobs to be safe I'd say.
I haven't used the wide-angle lens yet so the image in LeeB's post is great to see - I'm hoping to do exactly that this summer when I'm somewhere where there actually large enough vistas!
I have an old WO wedge (from when I used to use an iOptron SkyGuider Pro) and that is very good for moving more precisely along the directions the Dwarf 3 app tells you.  I use 60sec exposure and have not noticed much trailing - and BXT will clean things up anyway.
  • pfile likes this
#1562 Albut
Albut
  • Loc: London
Posted 18 June 2025 - 11:56 AM
I have purchased the D3 and can only compare it to my dedicated kit (AM3, TC-40 tripod, Redcat 51, asi183mc pro, asiair+, zwo guide scope/camera). It does not provide the definition I can achieve with my dedicated Astro kit, BUT it ain’t far off for many subjects. Like this one of the NA and Pelican nebula. Setting it up is a doddle. Easy for sun spots as well. So I am impressed for the price. Easier to take away when travelling.
  • beammeup, Skywatcher_neb, eyeoftexas and 1 other like this
#1563 vineyard
vineyard
  • Loc: London
Posted 21 June 2025 - 01:10 PM
@LeeB I may be being v dense, but is there a software update that does that?  From what I can tell, the wide angle lens is not available in Astro mode, it has be picked in Photo mode?  Thanks!
#1564 Albut
Albut
  • Loc: London
Posted 21 June 2025 - 02:03 PM
Dwarf 3, bubble/claw nebula. Processed in SIRIL. About 3 hrs of data. Processed SIRIL Hubble pallete.
  • Skywatcher_neb and mdowns like this
#1565 vineyard
vineyard
  • Loc: London
Posted 22 June 2025 - 09:48 AM
2h38 on a windy night!
  • beammeup and Skywatcher_neb like this
#1566 eyeoftexas
eyeoftexas
Posted 22 June 2025 - 09:50 AM
Very nice.  What are we looking at?
  • vineyard likes this
#1567 vineyard
vineyard
  • Loc: London
Posted 22 June 2025 - 12:15 PM
Oops sorry M24 and the small Sagittarius star cloud.  NGC6603 also v clear within M24.
  • eyeoftexas likes this
#1568 LeeB.
LeeB.
Posted 25 June 2025 - 03:20 PM
Here's how the manual says to do widefield shots:
https://help.dwarfla...strophotography
It seems like the tracking is done with the telephoto camera, but images are taken with the widefield camera. I didn't see a mention of how the autofocus works, but with the widefield view selected I hit the autofocus button, and so far I've seen respectable results.
#1569 vineyard
vineyard
  • Loc: London
Posted 25 June 2025 - 04:16 PM
Thanks - I'll try that tonight.
Here's 2.5hrs on M17 from last night.  I continue to be really impressed by the D3 - its smaller than a dictionary!
  • Skywatcher_neb, eyeoftexas and LeeB. like this
#1570 eyeoftexas
eyeoftexas
Posted 25 June 2025 - 05:31 PM
A picture is worth a thousand words…
#1571 Lumix
Lumix
Posted 25 June 2025 - 09:47 PM
Agree!
This is a "super-compressed" jpeg.
The Tiff is much better.
Edited by Lumix, 25 June 2025 - 09:48 PM.
  • eyeoftexas and LeeB. like this
#1572 vineyard
vineyard
  • Loc: London
Posted 26 June 2025 - 12:00 PM
The difference dark skies make.  I normally image from B9 (16-17 MPSAS) - the Dwarf3 is super portable and can be mounted on a tripod.  So it can come on holiday v easily.  Last night it was 20.9 MPSAS here (!) and this is 1h05 (!!) of data.
<SMH for light pollution in urban cities>
  • Skywatcher_neb and eyeoftexas like this
#1573 vineyard
vineyard
  • Loc: London
Posted 28 June 2025 - 04:01 PM
It worked, thanks!  (After I remembered to calibrate it with the proper darks and flats, doh!)
Edited by vineyard, 28 June 2025 - 04:03 PM.
#1574 Albut
Albut
  • Loc: London
Posted 29 June 2025 - 06:15 AM
Western Veil Dwarf 3. About 220 60s/60g. Processed SIRIL rotated cropped LR.
  • Boki, Skywatcher_neb, mdowns and 2 others like this
#1575 vineyard
vineyard
  • Loc: London
Posted 30 June 2025 - 10:30 AM
I can safely say that the Dwarf3 is now going to be a standard part of my holiday packing to go anywhere!
  • oneuke, Boki, Skywatcher_neb and 2 others like this
