What is this threaded part called? Spring bolt for tube rings?
Accessories ATM Equipment
2 replies to this topic
#1 Jacob.Redshift
Jacob.Redshift
Posted 17 May 2024 - 08:28 PM
The threads on this screw are partially stripped. This is the clamping mechanism for a set of tube rings. There isn't brand that I can find on the rings anywhere. It was a secondhand buy from an estate.
I was hoping to just replace the screw and not the whole tube ring set, but I'm having a tough time finding what it's called to find a replacement. I think it's technically a spring bolt and the internally threaded knob at the top end screws down on the bolt to clamp the rings together. The threaded bolt has a hole perpendicular to the shaft at the bottom so it can lever open and closed.
Thanks for your help folks!
#2 Jim Davis
Jim Davis
  • Loc: Lewisberry, PA
Posted 17 May 2024 - 08:42 PM
Rod end bolt. You can find them here: https://www.mcmaster...-rod-end-bolts/
  • Applal, Skywatchr, Jaimo! and 5 others like this
#3 Jacob.Redshift
Jacob.Redshift
Posted 17 May 2024 - 11:05 PM
Thank you, Jim! Now I've got to measure what size the thing is and order one.
  • Skywatchr likes this
Also tagged with one or more of these keywords: Accessories, ATM, Equipment
