I have 10 images of the Trifid in H that I cannot register in PixInsight. They are very typical of nebula images I take all the time except for one thing. They aren't great. There are probably a few reasons for this. The object is between about 20 and 29 degrees above the horizon, and the turbulence was terrible. I also have some mystery tracking/guiding problems I am working through. The PHD logs say 1.77" RMS during the time I took these. So, bad, but I would think they would register.
Images: https://drive.google...101?usp=sharing
Essentially, registration doesn't find any stars. And when I tweak the settings in Pixinsight StarAlignment, it can find stars but cannot find any pairs. I've explored many of the settings available. Interestingly, trying to stack in ASIStudio doesn't work either: triangle match failed.
These images were shot in Bin1 with an ASI294mm. When I resample the images to Bin2 size, they register just fine.
Is there some typical problem that I am just not seeing? I'm including a link to the original Bin1 images to avoid any issues with bias, darks, and flats. I've tried with and without those with the same results.
Any thoughts? Or are the images just unusable in the original Bin1 size? (I wouldn't normally care to keep these but I'm trying to understand why they won't register.)
Example output from the console with all StarAlignment defaults:
* Loading target file: /Volumes/Astro Drive/Trifid Nebula/2024-05-09 H/Light_M20_300.0s_Bin1_294MM_H_gain120_20240510-025219_0001.fit Reading FITS image: 16-bit integers, 1 channel(s), 8288x5644 pixels: done 76 FITS keywords extracted Structure map: Local maxima map: Detecting stars: done 9 stars found. Minimum star size: 3 px * Computing global linear transformation. Matching stars: done ** 0 star pair matches found - need at least 3 matched stars. * Previous attempt failed - this is try #2 * Reference image: limiting to 8 brightest stars. * Target image: limiting to 8 brightest stars. Matching stars: done ** 0 star pair matches found - need at least 3 matched stars. *** Error: *** Error: Unable to find an initial linear transformation.
