Solarquest DC adapter
10 replies to this topic
#1 supertrucker
supertrucker
  • Loc: weatherford texas
Posted 19 May 2024 - 01:23 AM
Can someone please give me a link to a DC adapter that will work on a solarquest mount. Thanks
#2 AstroTomK
AstroTomK
    Luminous Eyepiece Labels
  • Loc: Lyon Township, MI USA
Posted 10 June 2024 - 06:27 PM
I plugged this one in and it worked just fine: https://www.highpoin...RRoCKDUQAvD_BwE
  • supertrucker likes this
#3 reubanks
reubanks
Posted 10 June 2024 - 07:29 PM
The Celestron power supply listed above should work well but unless you already have one, seems somewhat pricey because of the Celestron name.
Here is one that I bought for a different project, but with similar specs. I plan on using it with my Solarquest this weekend if the sky is clear enough.
https://www.mouser.c...ail/374-T6640ST
Randy
#4 MVoltae
MVoltae
  • Loc: Madison, Wisconsin, USA
Posted 11 June 2024 - 08:13 AM
This two message posting is not in context for me.  Is there a lead-in discussion posted elsewhere?
#5 reubanks
reubanks
Posted 11 June 2024 - 10:15 AM
Jordan,
Supertrucker posted "Can someone please give me a link to a DC adapter that will work on a solarquest mount. Thanks". He received two responses with links to AC-DC adapters that should work with the SolarQuest mount.
No lead-in, just a request for info and two valid replies.
Randy
#6 phobos2
phobos2
  • Loc: New Bedford Massachusetts
Posted 13 June 2024 - 05:24 PM
Randy
Late to this, but how did this work out for you?
#7 reubanks
reubanks
Posted 13 June 2024 - 07:33 PM
Phobos2,
It's only Thursday so have not had a chance to try the PSU on the SolarQuest, but it works great in the mesh network node for which I originally purchased the product.
Randy
#8 BYoesle
BYoesle
  • Loc: Washington State USA
Posted 13 June 2024 - 11:09 PM
I use one of these $4 gizmos with the supplied 12 v adapter and a cheap $4 12 ft extension cord.
No need for anything fancier.
Edited by BYoesle, 14 June 2024 - 10:05 AM.
  • phobos2 likes this
#9 reubanks
reubanks
Posted 13 June 2024 - 11:52 PM
I just one of these $4 gizmos with the supplied 12 v adapter and a cheap $4 12 ft extension cord.
attachicon.gif AC-DC-500-Mah-Universal-AC-DC-Power-Socket-Adapter-Converter.jpg
It's bad that the manual for the SolarQuest doesn't give a power requirement for an external 12V supply. I'd personally prefer something bigger than 500ma for this if for no other reason than to not have it fail 30 minutes before an ISS transit. (knowing my luck...)
#10 BYoesle
BYoesle
Posted 14 June 2024 - 07:19 AM
I have used my small 110 AC to 12 v DC 0.5 amp adapter for my Solar Quest all day long without a single fail in two years of outreach and home use.
But you can of course go larger if you prefer.
A fresh set of batteries might last two + days. I always have a second set of fresh batteries on hand if AC is unavailable.
Edited by BYoesle, 14 June 2024 - 10:14 AM.
#11 reubanks
reubanks
Posted 14 June 2024 - 10:18 AM
Good to know! I bought the 2A supplies I referenced to replace some failed 1.5A PSUs that came with an ASUS mesh kit that eventually reached a 75% failure failure rate. I picked up a spare "just in case", which is why I have it in stock.
I might as well use what I got!
