Hello Cners,
Most of my NVA endeavors are well satisfied with one of my APO's most notably my TSA 120, FS 76 and TS C-F 155, on occasion a 12.5" Dob OR C8 Edge HD rounds out the NVA scope line up. Over the last couple of years, I have been curious about using a small fast Newt. I don't know if others out there get Email or pop up ads from the Astro Toy companies but I do and at times it is actually a bit scary when the sale ads are tuned for equipment that you were just thinking about. Any way H.S. sent me a pop up sale ad for the Apertura Carbon Star 150 F/4 Newt. This little fast Newt checked off a few of the design specs that I desired. The carbon fiber tube is very ridged and the Carbonstar has a massive sturdy focuser and I knew that these two things alone would help stabilize the NV visual stack that occurs if you are using an afocal arrangement. Upon receiving and removing the Carbonstar 150 from the box, this Newt is a good looking scope and the manfacturing quality is excellent. The Carbon fiber tube is very ridged, the focuser is big and sturdy and operates very smoothly. The spider is also quite ridged and strong and should be stable. There is no need for flocking the internal tube is baffled and coated with a flat black non reflecting finish. Although there is no sign of who manufactured the Carbonstar 150, for Apertura, I am pretty confidant that it is a GSO product. The Newt came with parallax rings and two sturdy dove tail plates, a Vixen and Losmandy D style. The only real goof up on GSO's part, is this Newt came with a set of wrenches that I quess were ment for some other scope and did not fit anything on the Carbonstar, fortunately I have the tools and this was not an issue. I assembled the the scope and mounted it for collimation. Like my 12.5" Discovery Dob, I started out with the secondary mirror and barlowed laser and fine tuned it with a Cheshire. The collimation process was straight forward and text book at least I thought, more on that later. I remembered Cuive, having to fix the pinched primary optics in his Carbonstar and this being a quick easy fix, I decided to go ahead and remove the primary mirror cell and yep the mirror clips were very tight and I loosened the screws a bit and reattached the primary mirror cell (I guess GSO does this for shipping) so I recollimated the Carbon Star. Then came the new Astro Toy curse and I waited and I waited for clEar skies. After a few days I had partially cloudy skies and decided to give the Carbon Star a test drive. The first light was with my 26 Nagler without the light intensifier and the views were very weird, I thought, oh yeah, I need to put in the Paracorr, so I did so and tried to tune it and this corrected some things but the views were still weird. The issue is this fast Newt unlike my Dob, this Newt is very particular with collimation errors. Unfortunately my skies only gave me a short window and I spent most of the time window getting the Carbonstar collimated before the skies became completely overcast. I took my time and got the collimation done the best I could and then the new astro toy curse returned and I waited and I waited. Last night the skies cleared early in the morning and this was perfect with my favorite time of the year at hand with Sagitarius and the Summer Milkyway rising into view. I set everything up for NVA. the Collimation was still spot on and this little Newt does not disappoint. Using a PVS 14, TV 67mm plossl, 685nm IR Longpass and 2.5nm Ha filters. The views of the Milkyways star fields, Nebulae and prominent dust lanes are sharp and bright and I could easily view alot of Nebulocity around and between The Lagoon and Trifid Nebulae. The Pillars of Creation in the Eagle Nebula are too small to pick out with the 67mm plossel and next time I will try the 26 Nagler and see if I can see the Pillars. Anyway the bottom line is, I was able to answer my questions on how well a small fast Newt works for NVA. I'm not sure how fast this scope is operating with the PVS 14 but it is fast. The Apertura Carbonstar 150 F/4 does not disappoint and will be a compliment by providing an entirely different viewing experience from my APO's.
HAPPY SKIES AND KEEP LOOKING UP Jethro
Edited by Jethro7, 20 May 2024 - 09:59 AM.
