HI All,
I would like to have your input using the ASI 174mm for Ha imaging and if you had issues with Newton rings or inference bans. Please let me know if this has been an issue for you too.
I just finished a exhaustive testing on what was causing my inference bans. I did not have rings, but a section in the middle of the frame had straight bans. Everything was fine if the 174mm was used natively, but when I added either a 2.0 or 2.5x Barlow they appeared. So, I set out to try and figure this out. Here is the list of what I did and results that I got.
1) Rotate camera - No Change and the bans did not rotate with the changed camera position.
2) Tilt camera - No Change, This included many different degrees of tilt and rotation of tilt - No Change and the bans did not rotate with the changed position.
3) Tilt Barlow and Rotate Barlow - No Change and the bans did not rotate with the changed position.
4) Rotate Diagonal/blocking filter - No Change and the bans did not rotate with the changed position.
5) Rotate DS unit - No Change and the bans did not rotate with the changed DS position.
At this point I'm starting to think that it is something internal ( - Maybe between the two etalons???)
6) Changed the brand of Barlow - Was using a TeleVue 2.5x and switched to a Tak 2.0 Barlow. - No Change but the bans were a little lighter - I believe this was do to the decrease in the barlow power.
7) Changed Camera to the ASI 290mm with the Tak and televue Barlow - No BANS
So After all that, I assume that it is the ASI 174 that was causing the issue.
I would love to hear comments on what I did and the results that I got, along with your success with using the ASI 174 and barlow combo. If you use another camera of similar sensor size what is it and how is it working out for you.
The Image is the ASI174 w/ televue 2.5x Barlow. shows the bands
Steve
Edited by slepage, 19 May 2024 - 06:29 PM.
