Diagonal Lines in Edit
10 replies to this topic
#1 LIGISTX
LIGISTX
Posted 19 May 2024 - 07:10 PM
I have been relatively successful with DSS and editing in the past, but a few weekends ago I shot M51 and once I got the stacked image into Photoshop and started to really pull data out of it I started to notice diagonal lines in the image which are preventing me from stretching it very far.
This is a way oversimplified "cranked the exposure" in photoshop just to quickly and easily show what I am talking about.
Does anyone have any idea what is causing this? I shot over 2 nights, a good bit of light polution in Bortle 6 skies, ran an L-pro filter. This is 141 3 minute subs with ~20-30 each of darks, bias and flats. I use a AVX, I threw out about 1/5th of all exposures that looked to be non-circular stars. I also autoguide and was dithering and did 3x drizzle in DSS. Shot on Nikon D850. I have not experienced this before and am unsure what might be causing this.
As a result, I was only able to push M51 enough to get this out of it... which considering the light polution and extremely small size this appears on my ~450mm telescope, it isn't horrible. But I know there is more data that I just can't pull out of it due to running into issues with this banding. Current edit: https://flic.kr/p/2pRbw54
Edited by LIGISTX, 19 May 2024 - 07:12 PM.
#2 DanMiller
DanMiller
  • Loc: Pennsylvania, USA
Posted 19 May 2024 - 07:51 PM
What is your camera?  I only ask this because Canon is known for this.  All though, the banding usually goes from left to right.  Also, try GraXpert. It is stand alone and free. https://www.graxpert.com/  It actually is pretty good, so it might be able to clean this up for you.  Doesn't hurt or cost anything.
Dan
#3 LIGISTX
LIGISTX
Posted 19 May 2024 - 08:28 PM
Dan
Camera is Nikon D850, and I have not noticed this in any of my previous images... but I have not historically used a Light Polution filter or dithered. I have done both previously without this tho.
#4 bignerdguy
bignerdguy
  • Loc: Lewisville, TX
Posted 19 May 2024 - 09:02 PM
That looks like walking noise and the image is overexposed a bit.  Dark frame and flat frame subtraction should remove most of this in post processing.
  • RedLionNJ likes this
#5 LIGISTX
LIGISTX
Posted 19 May 2024 - 09:09 PM
This is after stacking with darks and flats.
I would agree, I should have exposed for shorter time especially considering the amount of LP (I don't know why I picked 180 seconds... I meant 120, oops....).
What exactly is walking noise?
#6 LIGISTX
LIGISTX
Posted 20 May 2024 - 01:25 AM
Dan
That seems to have helped. Not entirely, but I was able to pull more data out before it degraded. https://flic.kr/p/2pS81Y8
Thanks for the advice!
  • DanMiller likes this
#7 bignerdguy
bignerdguy
Posted 20 May 2024 - 01:27 AM
Check out this thread:
https://www.cloudyni...ise-what-is-it/
Apparently if i read it right if you dither your frames this should eliminate this noise.
Edited by bignerdguy, 20 May 2024 - 01:29 AM.
#8 LIGISTX
LIGISTX
Posted 20 May 2024 - 01:37 AM
Hmm, I was dithering, but maybe by not enough pixels… and only in RA. Maybe that is the cause? Good info, I may have to play with dither settings.
  • bignerdguy likes this
#9 LIGISTX
LIGISTX
Posted 21 May 2024 - 10:16 AM
One more thing to add to this, I split up the R G and B signal and the diagonal lines are much more present in the R.
Any thoughts as to why?
#10 sharkmelley
sharkmelley
  • Loc: UK
Posted 21 May 2024 - 01:34 PM
During white balancing of the D850, the red channel must be boosted by more than the blue, relative to the green.  Hence the red noise may become more apparent.
#11 LIGISTX
LIGISTX
Posted 21 May 2024 - 02:11 PM
Ah, that makes sense.
