How to get ZWO EAF Temperature Probe to work in NINA
6 replies to this topic
#1 geothomas
geothomas
  • Loc: Huntsville, Alabama
Posted 20 May 2024 - 04:36 PM
I have the ZWO EAF focuser and their external temperature probe. I have version 3.3.8 installed for the EAF. I have NINA v3 running on Windows 11 laptop. Still the Temperature Compensation remains greyed out. I reached out to ZWO with the following email:
Do you plan to update your EAF driver to allow it to work with NINA for temperature compensation? If so, any idea when that might be?
Their response:
Hi George
the EAF ASCOM driver provides temperature read out to sofwtare
the compensation is within NINA not the EAF
the EAF Is a dumb device and only will do what is commanded by ASCOM
Simon
When I look at the NINA documentation, it says:
Temperature compensation can be turned on or off here. Note that this is the in-driver temperature compensation.
Temperature compensation must be configured in the focuser driver
thanks
When I connect the focuser, I can see the temperature readout, but the compensation button remains greyed out. Is there a way to see if their driver is indeed outputting the value to enable compensation and if it is in the format needed by NINA? How do I configure the focuser driver?
Any suggestions on where to go looking next?
Much thx.
Edited by geothomas, 20 May 2024 - 04:53 PM.
#2 KTAZ
KTAZ
  • Loc: Scottsdale, AZ
Posted 20 May 2024 - 05:58 PM
Sorry for not answering your question directly; I don't own the EAF.
However, I do have a temp probe in my Optec focuser on my refractor. Do I use it to do compensation? Nope. I guess I just don't trust it.
I simply set Nina to run a AF every time the HFR changes by more than 5%. That seems to work really well.
Edited by KTAZ, 20 May 2024 - 05:58 PM.
  • geothomas likes this
#3 geothomas
geothomas
Posted 20 May 2024 - 06:10 PM
When I was using SGP, I found that focus compensation worked really well. It was much faster than frequent autofocuses. I would use it in combination with an AF once every 60-90 minutes depending on the expected temperature drop for the night.
#4 Juno18
Juno18
  • Loc: Long Beach, Mississippi, USA
Posted 21 May 2024 - 07:53 AM
I have a 5v ZWO EAF installed on my ES ED102.
I have a temperature probe and don't use it, but I did dig it up and plug it in recently to monitor my dew heater temperature.
I don't have NINA write the focuser temperature to the filename as I only want to occaisionally glance at the temperature in the Equipment Focuser tab and it works fine.
I just stuck it in my mouth to test it!
Here is an image of my Focuser window in NINA if this helps.
I’m running NINA in a Win11 Pro mini pc.
Edited by Juno18, 21 May 2024 - 09:32 AM.
#5 fmeschia
fmeschia
  • Loc: Mountain View, CA
Posted 21 May 2024 - 09:38 AM
In NINA, you can use the “Move focuser by temperature” to achieve temperature compensation even if the ASCOM driver doesn’t support it, as long as it provides a temperature readout.
#6 geothomas
geothomas
Posted 21 May 2024 - 04:53 PM
Just what I was looking for, thank you. Even though I'm fairly well conversed in SGP, learning a new tool is still a steep learning curve.
#7 archiebald
archiebald
  • Loc: Japan
Posted 21 May 2024 - 06:20 PM
I just got started in NINA and noticed that temperature compensation was greyed out too.
Does this simply apply to "Focus every xx degC change in temperature" or can it be used for predictive focusing?
Coming from EKOS, a recent update in their focusing module allows for predictive focus change based on temperature.  Initial calibration must be done based on temperature, but can also include RA DEC values to compensate for mirror flop for example.  After the extensive calibration, focus is updated by a few steps between every sub.
