Go for it!
GSO was smart. First they sell soda lime till that saturates, then BK7, now Quartz. They sell more that way, since some of the people some people will replace their mirrors with ones of the new substrate.
Quartz density is 2.65 vs 2.5 soda lime
Quartz heat capacity is 89% that of soda lime on a volume basis.
Quartz conductivity is much higher
CTE 5.5 x 10^(-7) is 1/16 that of soda lime
CTE for quartz is the clear win, though does not kick in till the glass cools enough to not give off thermals, after which the other glasses returned to normal shape. Sky and Telescope had an article on that.
Many here think high conductivity is good, but I believe conductivity being high is actually bad. It means it bleeds a lot more heat early on. But even after the heat is bled, I think it will keep up bleeding more than soda lime and pyrex would at that temperature being cooler only because it can keep drawing heat from the center. Heat flow from center is proportional to temperature gradient x conductivity. So it does not win by being cooler but instead just has worse thermals in the beginning. I am comparing thermals, though. As for the figure, yes, higher conductivity will get the mirror back to design shape faster, though that is not needed with such a low CTE.
Zerodur is all win and no tradeoffs, but is expensive. Pyrex is also all win against soda lime, but again expensive material and tougher so takes longer grind and polish. A thinner soda lime mirror can be polished as fast as the pyrex and cool faster. I think thinner soda lime is the all around win for cost, cooling rate, manufacturing ease, and fewer thermals. GSO timed it right though, with the market primed wanting quartz, they are giving them quarts. Same thing happened with BK4 vs BK7 prisms, for refractors. Above f4, BK7 is the clear winner and bubble free, yet the market associates BK4 as the higher quality, and manufacturers often make it to flatter tolerances and alignment just because that is who is paying.
Edited by MeridianStarGazer, 23 May 2024 - 10:36 AM.
