Sun in Ha: 5/21/2024
5 replies to this topic
#1 gstrumol
gstrumol
  • Loc: north of Detroit, Michigan USA
Posted 21 May 2024 - 10:44 AM
Took the PST out early this morning. Seeing was listed as below average in Astrospheric, and verified visually! wink.gif It was a fairly dull Ha sun this morning, compared to recent days; few and muted filaments, and only one prominent prom.
Here are the results:
(click to enlarge)
first taken with the zoom EP set to capture the full disk. Then setting it to maximum zoom (8mm):
(click to enlarge)
Finally, here is a comparison of two different tone curve shapes, applied to the zoomed image:
(click to enlarge)
A sinusoidal tone curve produces an inverted image that easily includes the prominences. Once inverted in GIMP you get dark prominences and a darkening around the rim, giving a hemispherical look to the disk. The more monotonically increasing curve (right) tends to remove the prominences but gives a more uniform disk appearance.
Edited by gstrumol, 21 May 2024 - 02:25 PM.
  • bigdob24, SeymoreStars, MalVeauX and 6 others like this
#2 David Rosenthal
David Rosenthal
    Imager Extraordinaire
  • Loc: NJ
Posted 21 May 2024 - 12:18 PM
Nice images Gary and thanks for the IMPPG curve samples, I struggle with that tool
  • gstrumol likes this
#3 David Rosenthal
David Rosenthal
  • Loc: NJ
Posted 21 May 2024 - 12:38 PM
Gary,
I took my last image into IMPPG, started with your curve, and tried this to keep the background dark and the proms visible. Kind of a cool effect.
Edited by David Rosenthal, 21 May 2024 - 12:42 PM.
  • hornjs and gstrumol like this
#4 gstrumol
gstrumol
Posted 21 May 2024 - 12:44 PM
Gary,
I took my last image into IMPPG, started with your curve, and tried this to kappa the background dark and the proms visible.  Kind of a cool effect.
Yes, that is the third type of tone curve I sometimes use. I call that one 'the hump' because of the initial bump in the curve before coming down and proceeding 'normally'. waytogo.gif
Edited by gstrumol, 21 May 2024 - 12:46 PM.
  • David Rosenthal and hornjs like this
#5 rigel123
rigel123
  • Loc: SW Ohio
Posted 21 May 2024 - 09:23 PM
(click to enlarge)
(click to enlarge)
(click to enlarge)
Does Gimp allow you to raise shadows?  I think if it can do that you can bring the proms out on that image on the right.
#6 gstrumol
gstrumol
Posted 21 May 2024 - 09:51 PM
It can be done with a modification of the hump:
(click to enlarge)
but it's a delicate balance of prominence and surface detail. And the prominences aren't as 'prominent' as in the other approach.
  • rigel123 likes this
