I have a HEQ5 that I always used with no issue at all with the "typical" FTDI RJ45 to USB cable. As I'm struck by nearly 4 months of bad weather, I decided to try to eliminate the cable and switch to a bluetooth or wifi connection for the mount, so I followed adaptor projects I found here or on the net, they all provide pinout connection as follows (this is taken from https://eq-mod.sourc...eqdirect2.htm):
so it seems that I have to connect cables to pins 1, 5, 6 and 8, so I made both the Bluetooth adapter and the Wifi one but I've never been able to connect the mount via EQ Toolbox (BT) or the Synscan app (Wifi) even if I could see and connect either to the BT and the Wifi.
Today I decided to look at the USB cable and to my big surprise I found that the cable connected are on pin 1, 2 5 and 6! And they're totally different from the above pinout map!
To make things worse, the official EQMod page show that for the EQDIRECT-USB the cables must be connected to pins 4, 5 and 6
Now I'm totally confused!!! What is the actual pin map I have to use? Can this explain why I can't actually connect the mount with the stuff I built? If I had to refer to the EQDIRECT-USB my cable should not even work, but it does... What's this all electronic voodoo stuff??? Please help!!!
