I should have stated that the “star” remained center in the EP, it was me trying to hold the phone camera up to the EP that makes it appear off centered in the pictures. You think the reflections could be due to light scatter from the Barlow?
Very likely.
Okay, so a yellow haze around stars and multiple reflections of the defocused star. These does not sound like anything involving Bob's knobs, the Feather Touch focuser, or collimation. Rather the yellow haze might be an artifact of the apparently very bright artificial star itself, or possibly the camera, and reflections are just that. There is some light bouncing around from glass surfaces somewhere. Possibly between the Barlow and eyepiece lenses. You see the reflection because the light is bright enough to show them. We sometimes see reflections between imaging filters and the protective glass covering the chip.
As for collimation, the first image looks pretty good for rough defocused collimation, but latter images not as good. That may be the camera is slightly off axis. It's not always easy to center the lens on the exit pupil. As for the yellow haze, are you talking about the brighter edge of the images posted above, or a yellow haze around a focused artificial star? Do you see it visually or in the camera? There can be any number of reasons, including the artificial source itself, the brightness of the source, and uh...thinking of some more. The brighter defocused image, the artificial source appears to be slightly yellow which is fine.
Edited by Asbytec, 23 May 2024 - 09:45 PM.
