Hello,
As some of you know, I recently took my RC6 apart and cleaned the primary mirror.
Since then things went from bad to better and then to good and than to bad again.
Trying to use cheap tools.
-- I bought a new laser collimator. It's cheap but much better than the one I had before.
-- Found some old instructions recommending to "reset" the primary.
- loosen the small set-screws on the primary and screw the larger screws all the way in.
- this helped a lot. adjusted the secondary with the laser collimator and everything was in a "close to good" state.
-- Found some instructions on using Bahtinov to fine-tune the primary
- move a bright star with Bahtinov to every corner
- adjust the primary for the worst corner until Bahtinov looks better.
- this seems to be working. I only adjusted one corner so far . My worst corners are on the top.
Currently, ASTAP reports 20% tilt.
May 23, 2024. Bortle 8.
NGC5466.
RC6 at native 1380mm. F9.
RST-135 mount. Guided.
7x120s. 14 minutes (clouds came).
Stacked in APP.
Processed in PI.
Edited by maxsid, 24 May 2024 - 04:30 AM.
