ToupTeck imx571 setting
5 replies to this topic
#1 takahashi-italia
takahashi-italia
Posted 24 May 2024 - 08:56 AM
Greetings,
I just purchased the Tuopteck Imx571, connected with Ascom drivers, it asks me for a series of settings, can you help me? The image is for aesthetic purposes only.
Best regards
David
#2 hyiger
hyiger
  • Loc: East Bay, CA
Posted 24 May 2024 - 10:07 AM
Greetings,
Best regards
David
Not sure what you mean by "aesthetic purposes only." I assume you are using this for astrophotography or no? What settings is it asking you for? Maybe post a screenshot?
#3 Arie
Arie
  • Loc: Netherlands
Posted 24 May 2024 - 10:57 AM
Just use the default settings and you”ll be fine.
I am doing nothing else for 10 years and am quite happy with the resullts.
#4 takahashi-italia
takahashi-italia
Posted 24 May 2024 - 09:56 PM
here's a photo
#5 hyiger
hyiger
  • Loc: East Bay, CA
Posted 25 May 2024 - 01:19 PM
here's a photo
I'm assuming the last 4 slider are:
Frame Rate
Gain
Black Level
Dew Heater (?)
For the gain, I would look at the documentation, find out what the unity gain number is and set it for that. On other IMX517 cameras like ZWO, this will be 100 but not sure for this camera.
#6 badgie
badgie
  • Loc: SF Area, California
Posted 25 May 2024 - 02:24 PM
I would recommend HGC, high full well, Gain 100.  Set your offset so you don't have any pixels reading zero value (note, don' worry about one or two pixels at zero if you have to crank up the offset)
I wouldn't recommend using unity gain, it is a meaningless as a setting.*
(The choice can be derived from how much quantization noise you are willing to accept.  However when you have noise > 1 adu, as is pretty much always the case in modern cameras, then quantization noise is vastly swamped by read-noise anyway.  In this case, as it is for your camera, choosing unity gain is almost always always non-optimal for other reasons.  For general dynamic range you want to shoot at the setting that maximized FWC/RN^2, this will get you the best DR  in your stack with no sacrifice to your noise)
