Have you tried using the fans while the mirror is still cooling? Do the front fans improve the image before the mirror has fully cooled? In any case, it's good to see you can speed up conquering the thermals, thanks for passing on your knowledge!
An interesting question. I’m fussy when it comes to my star images so I’ve gotten into the habit of letting my scopes cool before I do any type of observing. Rarely will I view within an hour after setting up and it’s usually to get a quick look at an object, like Venus or Mercury. Outside of that, I don’t bother. I really don’t like bloated stars. When the mirror is warm, nothing is really sharp and I do like sharp views in the EP.
Thanks for posting the video link, I had posted it in my Vendors thread, and shared it on my Groups.io group. A lot of work went into video editing by Sergio from SCAS.
Many don't realize that the star test is dependent on multiple variables besides the actual shape of the mirror. Therefore, when doing the star test you are seeing the effect of the mirror's shape, the temperature distribution in the glass warping the shape of the glass, the mirror cell support effect (rear and edge supports), and also the same things from the secondary mirror.
Uneven temperature distribution in the glass is caused by temperature changes, and this changes the shape of the mirror in a time-varying way. Therefore, I recommend experimentation to determine what results for the best performance with your particular mirror, telescope, and fan arrangement.
I agree the star test is dependent on variables such as cell support, secondary mirror quality + mounting + conditions it is exposed to, and seeing. Generally speaking, I don’t need seeing to be perfect to be able to discern optical anomalies in the star test. A few sessions ago, right after I replaced the spider + diag holder, I was seeing some significant stig which I traced to the secondary not being seated properly all the way around the lip of the astrosystems holder. It was binding where the two ends of the diag holder shroud meets which is the end near the focuser.
It was also packed extremely tightly with the batting, to the point where the backing plate popped out as soon as I unscrewed the last fastner. I fixed this by trimming 2” off the back of the foam plug and reducing the amount of batting in it. I also experimented with different ways to secure the shroud without binding the mirror. I ended up shimming half of the circumference of the backing plate that the shroud attaches to with electrical tape. Doing that enabled the shroud to wrap around the backing plate and the secondary mirror without the end nearest the focuser shifting upwards due to binding. The secondary is 5.5” and ¾ thick, so about ¼” thinner than most secondaries of this size. The shroud was made just a little too oversize relative to the backing plate. Shimming fixed this.
When I star tested tested after implementing the aforementioned interventions to address the stig, the seeing was terrible AND the mirror was not cooled at all (I didn’t bother even turning the fans on nor waiting for it to cool as it was a quick roll out to star test), I could see very clearly the stig was gone.
I do plan to experiment with the cooling fans if the star test tells me I need to. Right now, I have the fans angled so that the outer 75-100% zone + mirror edge is cooled by the fans, since the back 3 fans cool the center out to about the ~50% zone from the back. I plan to dial the fans back to see what happens to the star test. The sessions I’ve had it out, I’ve had all the fans all on maximum voltage.
Thanks for the write-up mate. How far up from the primary surface are your fans sitting? I can't quite pick from the first photo - you have them firing in at a slight angle? If this is the case, did you have to play around with the angle, or how did you determine it?
The distance between the mirror surface and the center of the fans as they are angled currently, is 10”. This seems like a large distance but I believe it works to my advantage. The shape of the air flow from the fans is shaped like an alluvial fan or river delta, so the air disperses over the surface of the mirror instead of a narrow stream of air being directed at a specific region on the mirror. For this reason I chose static pressure fans. When deliberating on which type of fan to install, one of the concerns I had about airflow fans was directing a narrow stream of air at a localized region of the mirror. I also used airflow fans in my son’s computer that I built, and they vibrate like nobody’s business. Generally, I find static pressure fans vibrate less than airflow fans.
I had to experiment to find the angle I thought would work most efficiently. I did by looking how quick and how often the tear in the middle of my mirror cover lifted when the fans were on. If it flagged like a flag in high winds, I decreased the angle of the fans towards 0° (lowered the fans) until the tear whiffed about, instead of standing on end. I also put my hands around the perimeter of the mirror area to make sure I wasn’t wasting air by directing the fans at too steep of an angle (towards the floor of the rocker).
Hope this makes sense.
I realized I didn't really break down how I wired the fans. I used a spool of 22 gauge wire and wired each of the four fans to a single female USB connector. I thought about daisy chaining them, but individually wiring each fan to wires that all meet where the USB female connector is, was a bit easier to do. The longest run of wire for the furthermost fan of the usb female connector is, if I recall correctly, 66".
All four fans are soldered to a single female USB connector that remains in the mirror box. I then made my own 6" male to male USB cord with an in-line voltage controller that connects to a 26,800mAh battery which also powers the 3 rear 120mm fans, which are also soldered to their own female USB connector. I also made a 6" male to male with an in-line voltage controller for the rear fans.
I plan to evidently make a switch board, so I can simply connect the battery to the board, and just use the switches on the board to control the fans. This would be on top of the mirror box next to the finderscope.
Edited by TayM57, 24 May 2024 - 09:08 PM.
