10-Panel mosaic of the Moon
Astrophotography Moon
6 replies to this topic
#1 nighthoek
nighthoek
  • Loc: Livingston, NJ
Posted 24 May 2024 - 10:51 AM
This was taken through my my Celestron C8, with the .63x reducer/flattener, UV/IR Cut filter, ASI533MC-Pro, using lucky imaging.  I shot 10 1-minute videos at 1080p, and then processed them all exactly the same in AutoStakkert, Registax and Pixinsight.  Then, I used Microsoft ICE to assemble the mosaic and final touchups were done in LightRoom.
The full resolution image and all the details can be found here: https://astrob.in/rj9zrw/0/
  • Kenny V., John_Moore, AstroFrankMontana and 6 others like this
#2 Borodog
Borodog
  • Loc: St. Augustine, FL
Posted 24 May 2024 - 10:54 AM
Good effort, wrong forum. :O) Don't worry, it will get moved.
Why did you need 10 panels? 4 should do the job.
  • nighthoek likes this
#3 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 24 May 2024 - 11:02 AM
I thought so too.
Why the 1080p when 533 is 3008x3008 pixels? Ah, it could be a AA Pro limitation.
Edited by Tapio, 24 May 2024 - 11:04 AM.
  • nighthoek and Borodog like this
#4 RedLionNJ
RedLionNJ
  • Loc: Red Lion, NJ, USA
Posted 24 May 2024 - 12:44 PM
Apparently the guidance at the top of the M&MPI forum is escaping too many lunar imagers these days:
A reminder. It says:
Posts about imaging our Moon should go in the target-oriented "Lunar Observing & Imaging" forum.
This post has been moved, but since there were already replies, it will also be visible from M&MPI.
  • JMP, frank5817 and nighthoek like this
#5 Borodog
Borodog
Posted 24 May 2024 - 12:47 PM
I thought so too.
It's possible he wanted to also upload the full resolution videos to youtube or something, which is perfectly acceptable. If I wanted to do something like that I would make a cropped video from the full resolution videos using PIPP, though. Or he could be worried about field curvature, but as under-sampled as he would be, it's a non-issue in my experience. I don't even worry much about field curvature in my reduced C8 with my 2.4 micron pixel 183, much less the 533.
#6 nighthoek
nighthoek
Posted 24 May 2024 - 03:28 PM
Thanks.  I used 10 panels, to make sure I got everything.  In the past, I've had areas that were missing.
#7 nighthoek
nighthoek
Posted 24 May 2024 - 03:29 PM
I thought so too.
The highest res video for for 533 and AA is 1080p.  That's the limitation.  I should have used firecapture on my laptop.
Also tagged with one or more of these keywords: Astrophotography, Moon
