Sometimes when we make a mess of things we have to think out of the box to effect a solution.
When I rebuilt my CEM120 dual ring I only roughly polar aligned the Tri pier 360 tripod before installing all the equipment and counterweights. I would guess that installation weighs around 250 ilbs and there was no way to just lift & shift into the right position- I'm not superman and perhaps are more aligned to being weak & weedy TBH but I digress.
I took my Silva compass (no electronic gizmo for me) and attached a piece of stretchy string to two bolts about 3 feet long and I aligned this string as parallel as I could to the RA tripod leg along the North/South plane of the compass. Taking the rubber mallet I gently tapped the RA leg and finally the rear legs to get the RA axis leg parallel to the string. This took a lot of gentle nudging as you cant really wack the legs really hard- I was careful to disengage the mount worms as well- after a good few minutes I had a pretty good visual alignment of the tripod RA leg parallel to the string. I don't think the vibrations of the mallet reached the optics as there is a big hunk of metal & counterweights to absorb a lot of the nudges.
I then planned to firstly run an alignment using the hit & miss CEM120 IPolar that I had fitted and finally a three point NINA alignment. I did a quick test of the altitude adjustment knob- that great big lump of aluminium with the graduations and.....it was expected locked tight as the retaining altitude bolts had not been loosened. I tried an Allen key to loosen one of the bolts with only an intentioned quarter turn as mentioned in the manual- the allen key was actually bending.... as well as my fingers going blue/white but the bolt would not budge. I resorted to a ratchet 3/8" fitted hex key and that moved the bolt. The other side was not "welded" as bad. I could now finally move the mount in elevation. I tightened the bolts back down ready to come back later to see how succesful I'd been with the compass, string and the rubber mallet beating that I gave the Tri-pier.
Well......it has gone cloudy.....its been ages with cloud & rain......I will let you know when I can test.
The weather......sucks!
I wish all of you clear skies (I will be jealous if you get some).
Edited by pyrasanth, 24 May 2024 - 03:02 PM.
