An issue with ASI 6200 MM PRO 1x1 Bin
3 replies to this topic
#1 pyrasanth
pyrasanth
Posted 24 May 2024 - 07:07 PM
Tonight my ASI 6200 MM PRO developed an issue where 1x1 bin mode is behaving very strangely. The images when stacked have a weird pattern and when zooming the image is full of strange spots and noise. On a single sub the SNR seems very low.
2x2 bin mode & lower works just fine. I could remove the drivers and reinstall however I' thought I would get the forums opinion as to whether you think this might be a software or hardware issue.
I have sent the images to ZWO support. The integration is 11 frames, 1x1 bin gain 100 offset 50 and calibrated with a dark of same and bias. No flat was used.
I've attached a zoom of the center area as well.
Please let me know your thoughts.
#2 andysea
andysea
  • Loc: Seattle, WA
Posted 24 May 2024 - 08:51 PM
I don't know what could cause the mesh pattern that I see in the first image.
The second image almost looks like ice crystals. Just a wild guess tho.
#3 Cryhavoc38
Cryhavoc38
  • Loc: Woodinville, WA
Posted 25 May 2024 - 01:52 AM
Almost looks like a spiderweb
#4 pyrasanth
pyrasanth
Posted 27 May 2024 - 05:56 PM
I identified what caused the issue. The setting in NINA for cooling had been reset from 30 minutes slow cool down to 0 minutes. This caused what I suspect was either ice or condensation on the sensor which could not be dealt with with the dessicant in the camera. The error, for a reason unknown, did not show in the 2x2 bin subs but a closer inspection of these subs later revealed that they are noisy.
