I have an 8” classic dobsonian telescope from Skywatcher’s classic collection. I got it because of it’s cheapness, but am now wanting some more out of it. Would I be able to turn this into a tracking telescope? If so, how would I do it for as non-expensive as possible?
Thanks, Maximus
If you simply want an easy way to find stars, purchasing the Celestron StarSense adapter and code would be the cheapest option. You can buy the parts you need second-hand or purchase the cheapest StarSense telescope and use only the necessary parts.
Another method is to buy or build an equatorial platform. In South Korea, where I live, there are no people making these, so I had to make one myself. There are also methods on YouTube showing how to make one for $100. An equatorial platform can track objects.
Therefore, if you have a StarSense adapter and an equatorial platform, you can try many interesting things.
That is the same method shown in the photo below. To reduce curve, I attached an auxiliary battery, which also charges your phone, helping you observe for a longer period.
Buying an astroid is also a good option, but it is more expensive than you might think.
This would be the most economical option.
This is not a method I use anymore, because the Push-To function of SharpCap Pro replaces it.
It is because this method finds targets more accurately when taking photos.
I will leave you a YouTube link that might be helpful. It is a video on how to make an equatorial platform for 90 dollars. I found it very interesting, and I think it will be helpful for you as well.
https://youtu.be/Q6o...7VVZ1xk9eJurPH6
Edited by yong ho jang, 29 May 2024 - 09:18 PM.
