Here I am! I am now „more in“ than before. I rebuild my PC including SSD. Also I switched from the Samsung Galaxy S7 to S20, which you already know!
Ok, after seasons of auto-stacking Lights in Siril with scripts, now I am learning manual stacking lights, but my stacking not work! I got always this two warnings:
MAD is null. Statistics cannot be computed.
Normalization failed. Check image 156 first.
Stacking failed, please check the log to fix your issue.
My Stacking settings are:
Method: Average stacking with rejection.
Normalisation: Additive with scaling.
Rejection: Winsorized Sigma Clipping.
Weighting: Number of Stars.
Image Rejection: selected
Output normalisation: yes
RGB equalization: yes
Errors I got in any seasons. Registration goes normal (like 157 of 335, normally for me).
Did I try repair what logs suggest me? Yes.
In every stacking show me about 10 numbers image warnings.. I remove (uncheck) that 10 pictures, stack againg, and after that it shows me new warnings with other numbers of pictures. That process I can repeat unit ALL pictures are deleted, there is no end! (tested at 50 pictures, all I deleted). So, it seems that Siril not accepts any of pictures with current setting: „Normalisation: Additive with scaling“ (or any other normalisation).
WEIRD THING:
How is possible that SCRIPT (OSC without DBF)
successfully finish stacking process with included „Average“ and „ Additive with scaling" (in text log)???? I confused, why not work manual? Is that means that must work in manual stacking too?
METHOD WHICH WORK:
Otherwise, I found a method which works: disable Normalisation, like:
Normalisation: None
Is it normalisation important and how much? Does it ruin a picture if is disabled?
Also working Sum stacking and Pixel (min and max) stacking, which have normalisation disabled by default, but it seems to give me the worst results in the image.
I remind you that I have ALT/AZ mount, where I have field rotation. My target not all time in season
„in center“, I check it every 15-30 minutes and sometimes must recenter position. Maybe because of that normalisation failed.
I saw in log some .log "memory" word, is it problem in memory PC?
With pictures I am sending my main stacking log (which not work) and script stack log (which work) to compare.
Edited by Smurf, 08 January 2025 - 02:28 PM.
