M17 Tri-band Vs. No Filter
Astrophotography CMOS Imaging Reflector
10 replies to this topic
#1 Mikeiss
Mikeiss
  • Loc: Tucson
Posted 27 May 2024 - 06:17 PM
Here is a comparison of M17 the Swan nebula taken with my Vixen ED81S with the .67 reducer and my ASI174MC-Cool. I originally intended to use my Antlia Tri-band filter, but I forgot and ended up shooting with no filter at all. I then got roughly the same amount of time but this time with the filter. For fun I also tried using both pictures, using the shot with no filter for my luminance frame, and the shot with the Tri-band for the RGB. I like them all, but I'm curious to know what someone else thinks. The shot w/no filter was 213x60s, and the shot with the filter was 225x60s. Due to their file size I'll have to make an additional post for the extra pics. Thanks for looking and clear skiessmile.gif
-Mike
  • mikewayne3 likes this
#2 Mikeiss
Mikeiss
  • Loc: Tucson
Posted 27 May 2024 - 06:18 PM
#3 Mikeiss
Mikeiss
  • Loc: Tucson
Posted 27 May 2024 - 06:21 PM
#4 Mikeiss
Mikeiss
  • Loc: Tucson
Posted 27 May 2024 - 06:25 PM
I forgot to list the programs used for processing, oops. DSS, Graxpert, Siril and Photoshop CS4.
  • Cryhavoc38 likes this
#5 licho52
licho52
Posted 27 May 2024 - 10:13 PM
Filter never adds, only subtracts, you gain nothing from a non-narrowband filter.
Narrowband filters work but only because of the narrow part and the narrower the better.  These broad-filters that promise magic are just glass beads.
#6 Mikeiss
Mikeiss
  • Loc: Tucson
Posted 27 May 2024 - 11:37 PM
I use the filter for light pollution and it does that fairly well. It's not like I said "look how much better this is with the filter." And I like it which is what matters.  Good day
#7 Cryhavoc38
Cryhavoc38
  • Loc: Woodinville, WA
Posted 28 May 2024 - 01:09 AM
Once you stack in siril, do a pcc color correction and then use starnet++ via siril integration to remove your stars so that you can process your nebula and stars separately.
Download the cli version of starnet and setup siril to use it directly via the star processing menu in siril
  • Mikeiss likes this
#8 Mikeiss
Mikeiss
  • Loc: Tucson
Posted 28 May 2024 - 01:58 AM
I've already downloaded it. Just not quite comfortable yet with starless processing, practice makes perfect though. At least that's what they say.
#9 Mikeiss
Mikeiss
  • Loc: Tucson
Posted 28 May 2024 - 02:14 AM
Let me just remind people that I asked which picture other people thought was best. I didn't exactly ask for constructive criticism or to be told how inferior my filter is. Let me just say that I can completely understand why some people get frustrated  and don't bother with this website.  Thanks
#10 smiller
smiller
  • Loc: Vancouver Washington (not BC!)
Posted 28 May 2024 - 08:42 AM
Nice comparison, thanks for sharing.
Perhaps what licho52 was trying to communicate was that if M17 is almost entirely an emission nebula then the narrower the filter the better and so an even greater difference in your imaging productivity could be had with an even narrower dual band filter.
But, with those you usually lose the SII, Hb, and some or all of the Oiiib and Nii, so this may be very target, imaging goal, and sky darkness related.  Also, some of the narrower filters pass less of the primary narrow bands (85-90%) instead of the ~96-98% (according to one tested filter) of your filter.   So I would say that for OSC filters although narrower is generally better on emission targets, general answers on the optimum choice can be complicated and it’s a topic that is regularly debated.
Edited by smiller, 28 May 2024 - 09:05 AM.
#11 Cryhavoc38
Cryhavoc38
Posted 28 May 2024 - 02:11 PM
Since you asked, and because I use the antlia tri band alot, I am going to say that the first two look nearly the same and the 2nd and 3rd image are really wanting to be processed to get the color brought out of the nebulosity.
The stars are monochromatic because it appears you processed the entire image the same, whereas the stars really benefit from an initial photometric color calibration and asihn stretch to preserve their true color.
Practice does indeed make better, but please practice by separating your stars from the main dso object and recombine them all once you are satisfied with the dso processing.
Also tagged with one or more of these keywords: Astrophotography, CMOS, Imaging, Reflector
