I had clear skies last night, and got a start on the challenge list.
NGC5529, CC8 x 0.67, ASI2600MC bin 2, UV/IR, 45 x 60", darks, flats, guiding
The CC8 suffers from vignetting with a crop sensor. Even with flats, some vignetting survives, and I usually clip the background in the Live Stack Histogram to remove it. I am trying a lighter touch on clipping, however, so the vignetting is apparent in this shot. I also processed in Pixinsight and this is my first time using Brent's suggestion for comparing the SharpCap Live Stack with the processed image. If you click on the thumbnail, you will see the saved-as-seen PNG, and if you hover the mouse over it, you will see the processed image, for comparison.
There is not a lot of detail for the galaxy in either version. I see a little more structure in the processed version. I count 8 very dim galaxies in addition to the main one in the EAA version. I count 10 in the processed image, and a few of them even have structure rather than being simply fuzzy blobs.
NGC6210 (Turtle Nebula), CC8 x 0.67, ASI2600MC bin 2, UV/IR. 45 x 60", darks, flats, guiding
I had to be more aggressive with the Live Stack Histogram on this one, to reduce the diffraction spikes that would otherwise obscure any structure. There are at least two tiny arms on the nebula, but otherwise it appears as a featureless blue ball. Processing in PI reveals no additional detail.
NGC6210 (Turtle Nebula), CC8 x 0.67, ASI2600MC bin 1, UV/IR. 101 x 10"
The nebula is bright enough that I tried using SharpCap's Planetary Live Stack on it. The central star is now visible, and while the nebula is tiny, it is no longer featureless. I used a 50% stacking filter, which led to some improvement in contrast. With planets, people typically use sub-second exposures to take advantage of clear moments in the atmosphere. I played around with gain to get the shortest possible exposure, but below 10" the nebula was quite dim.
NGC6543 (Cat's Eye Nebula), CC8 x ).67, ASI2600MC bin 2, UV/IR, 45 x 60", darks, flats, guiding
Similar story for the Cat's Eye nebula. The traditional Live Stack reveals very little structure to the nebula. Close examination reveals a central star and a nebula that is not circular.
NGC6543 (Cat's Eye Nebula), CC8 x ).67, ASI2600MC bin 1, UV/IR, 100 x 10"
SharpCap Planetary Live Stack revealed quite a bit of structure to the Cat's Eye. The details may be artifacts of the planetary sharpening, however. My image bears only a passing resemblance to the most detailed images on Astrobin: https://astrob.in/bigd0b/0/ (C14, 8 hours integration). I was able to bump the gain down to 100 for this bright object. It might have been better to leave the gain at 300 and reduce exposure. An experiment for another non-cloudy night.
NGC6572 (Blue Raquetball Nebula), CC8 x 0.67, ASI2600MC bin 1, UV/IR, 100 x 3"
I tried using shorter exposures on the Blue Raquetball. With the Planetary Live Stack, I can at least see that it is oblong in shape. I didn't do a traditional Live Stack on this one. Hey, it's only the first of the month.
NGC7160, CC8 x 0.67, ASI2600MC bin 2, UV/IR, 30 x 20", darks, flats, guiding
There was no real advantage to post processing this image, so, of course, I did so anyway. A mouse hover on the EAA image just shows that processing brought up background stars that were clipped in the Live Stack Histogram. I din't see any nebulosity to this cluster.
