Problem aligning Meade LX 200 Classic
#1
Posted 27 May 2024 - 09:29 PM
#2
Posted 27 May 2024 - 09:44 PM
Assuming you had the lens cap off, I would take it out in the day, find something off in the distance, and try to focus on that. I find getting the focus reasonably close, and then getting the guide scope aligned (assuming you are using one) to the same object is much easier in the daylight.
John
- JohnBear likes this
#3
Posted 27 May 2024 - 10:34 PM
Do you have any kind of finder? A red dot, a Telrad, or a small finder scope? Trying to find a star with just the eyepiece is REALLY difficult. Is this a new scope?
As John said, practice with this in daylight. If you don't have any kind of finder, at least get a red dot or Telrad ($40).
#4
Posted 27 May 2024 - 11:01 PM
Welcome to C/N!
The Meade LX 200 SCT came in an 8" & 10" model. Both have long focal lengths that as mentioned will be almost impossible to find anything without a properly aligned finder scope. They usually came with a simple straight through optical finder like 8x50. During the day zero in on a distant telephone pole or similar using only the telescope. This takes time and patience so plan for both. Then lock the scope down so it won't move. Then adjust the cross hairs on the finder scope to agree with the telescope. Now you are ready for the night sky...Good luck!
- ShaulaB and JohnBear like this
#5
Posted 28 May 2024 - 12:13 AM
try Arcturus, it's way bigger. and use a finder. the big scope focuser will whizz right the the focal point if ur turning too fast. .
- ShaulaB likes this
#6
Posted 28 May 2024 - 05:06 AM
The focus on a SCT has many many turns.
Don't be afraid to make a lot of turns, the end stops are obvious.
Start during the day as sevenofnine suggests
#7
Posted 28 May 2024 - 11:08 AM
Once you have it focused, you can align the finderscope. Once the finderscope is aligned, you can try a GoTo alignment .
