I'm in the UK and quite new to astronomy and am visual/observing only. I bought a Celestron Nexstar 6SE around 6 months ago. (f/10, FL 1500mm)
I initially compiled a set of 7 eyepieces, mixed between new, supplied, & 2nd hand purchases. This range comprised of: -
- Celestron X-CEL LX in; 7mm (x214), 9mm (x167), 12mm (x125), 18mm (x83)
- BST Starguider ED 15mm (x100)
- Supplied Celestron 25mm Plossl (x60)
- Meade 4000 Super Plossl 32mm (x47)
This is obviously a full set of eyepieces, and I understand that an f/10 scope is particularly undemanding on EP's. So logic suggests all is well in the world, and I should stop right here.
...However, I decided to replace the supplied Plossl, and having spent far too much time on CN, started to explore Tele Vue. This led to a return to the 2nd user market, and a quick fire succession of purchases;
- Tele Vue Plossl 32mm (x47)
- Tele Vue Panoptic 24mm (x63)
- Tele Vue Panoptic 19mm (x79)
Clearly these now displace the supplied 25mm Plossl, the Meade 32mm Plossl (bad buy that anyway I think? - its the Chinese version) and also the XCEL LX 18mm.
I'm in no rush to move on the displaced EP's, but am considering what my next moves should be in the medium to higher power FL ranges.
My 'draft plan is to add a x2.5 Powermate to the two Panoptics I now own, which will give me:
- 24mm = 9.6mm / x156
- 19mm = 7.6mm / x197
Then later replace my 15mm BST StarGuider with either a TV Delite 15mm (or possibly TV Delos 14mm). Delite would give me x100 and with the Powermate, 15mm = 6mm / x250 (for that one UK clear seeing day a year!)
The end game therefore would look like: -
- TV Plossl 32mm = x47
- TV Panoptic 24mm = x63
- TV Panoptic 19mm = x79
- TV Delite 15mm = x100
- TV Pan + PM = x156
- TV Pan + PM - x197
- TV Delite + PM = x250
- I would then head out with a case of just 4 x EP's & one Powermate
- The AFOVs (excluding Plossl) are all between 62 - 68 degrees. (so no huge divergence/disparity when moving up and down powers).
- I'd have a heap of Celestron, BST & Meade EP's to sell off!
- I do have the f6.3 focal reducer too, so can also get slightly wider fields on the lower power EPs, without starting to get complex with 2" EP's - that's not for this scope, IMHO.
My main concerns are the use/wisdom of bringing in the Powermate, the range of magnifications I will have and if any are unwise/too close, if I still have too many EP's, and any other unknowns I may not have been aware of due to my inexperience.
Thanks in advance for any comments!
(Nb I fully anticipate Don Pensack saying scrap the whole plan and buy the entire TV Ethos range instead!)
Edited by Chirpy73, 29 May 2024 - 02:31 PM.
