I understand the capacitors in various places of the "Classic" Meade LX200 electronics are weak and should be replaced (especially the one under the ribbon in the HC...might do that one anyway) but as the electronics are designed for 18v is it safe to use 12v instead?
And what are the downsides to using 12v? I believe the slewing is slower but will the relatively low voltage raise havoc with the computer or have other negative effects?
Tom Duncan
