It's been a few years since I've posted, but I'm finally getting back into it again. I'm an amateur photographer and have always been interested in astrophotography. Unfortunately, my budget did not allow for much and I ended up with an LXD75 EQ mount with a Burgess 102mm f/6 scope. I was able to attach my 5D Mark II and start capturing a few shorter exposures as I did not have any auto-guiding at the time. Frustration set in as I knew I could do better. Now, four years later.... over the last four years, I started building my new setup and was able to finally get the last pieces about a week ago. After much research, and knowing my limited budget, I settled on the following set-up:
ZWO AM3 Mount
ASIair Plus
AT72EDII Scope
SVBony guidescope
ZWO ASI220MM Guide camera
ZWO ASI533MC Pro Main Camera
A few nights ago it was clear and I had just enough time to get the setup outside and run it through polar aligning, selecting and object, and getting auto-guiding going. To my surprise, focusing the guide camera was the most difficult part of the process... but thankfully, once focused, I never need to focus it again. Getting the ASI533MC focused in didn't take but about 5 minutes of my time and then came polar aligning. Again, to my surprise, this was the fastest polar alignment I have ever achieved, getting it done in under 10 minutes. I was able to get guiding setup and running as well - seems that ASIair takes about 5-7 minutes to properly get the guiding going, which is completely fine and acceptable. Once set, I slewed over to M101 and decided to put the guiding and camera through a test, pulling in a full 600 sec exposure - I wanted to see if there would be any drift in the guiding. Below is an unedited JPEG of the shot I was able to get (pulled from the ASIair)
Overall, I was very pleased with how this shot turned out and how the equipment was so easy to setup and use. Now I need to get myself a dew heater and prepare for a full night of capturing data!!
Unfortunately, I only had enough time to run these simple tests as clouds quickly moved in - figures this would happen when wanting to try out new equipment! However, tonight will be clear and I plan on spending some good time getting to know my equipment and capturing a true first light.
Praying that skies stay clear as predicted!!
