I recently purchased an RC6 and I'm trying to dial in the guiding. The best I can get at the moment is 3-4 arcseconds.
Here's my current setup..
> iOptron RC6 (1370FL)
> HEQ5 Pro
> 70mm/420FL refractor for guiding. (Just because I have it. I have a smaller 30mm/120FL guide scope, but as I understand this is too small for the RC6.)
> Svbony SV905C 1280x960 for guide cam.
> Using PHD2
> Bortle 8
I have another rig about the same weight, with the smaller guide scope, and I can usually get .5-1.0 arcseconds.
Given the above setup, should I be able to get guiding down to under 1.0? If so, any suggestions as to where to concentrate my efforts?
If I were to go with an OAG, how much easier (or harder) would it be to achieve good guiding?
Would a filter of some sort (light pollution?) help on the guide scope?
Also, with both of these setups in the same weight range, my HEQ5 counterweights are near the very end of the bar. Would it make any difference if I were to get an extension bar and move one weight farther down? (And the other one up.)
Any tips or suggestions appreciated, thank you!
-Steve
Edited by KSPSteve, 30 May 2024 - 09:59 AM.
