Nikon D800 and Pentax 645 FA 300mm f/4
3d printing DIY DSLR
11 replies to this topic
#1 Astrofriend
Astrofriend
  • Loc: Stockholm, Sweden
Posted 04 June 2024 - 05:12 AM
My latest project.
Camera:
A Nikon D800 full frame camera. First thing to do, remove the IR filter and the others.
http://www.astrofrie...nikon-d800.html
In somehow remote control it from KStars/Ekos or PC Windows with APT.
Lens:
A Pentax 645 FA* 300mm f/4 ED lens
http://www.astrofrie...45fa-300ed.html
Make them fit together with 3D printed parts
Add Off-axis adapter
Add Tilt adapter
Longtime project for sure.
Lars
Edited by Astrofriend, 04 June 2024 - 05:15 AM.
  • GTom and Helyis like this
#2 Astrofriend
Astrofriend
Posted 27 July 2024 - 09:45 AM
Today I started to design the adapter that will connect the Nikon camera to the Pentax 645 lens. I have divided it in two different devices to get it easier to 3D-print.
Here is a prototype of the end of the adapter that connect to the Pentax 645 lens:
The camera and the lens weights 2.7 kg together, I'm not sure if the strength of the adapter will be strong enough.
Lars
#3 Astrofriend
Astrofriend
Posted 02 August 2024 - 05:02 PM
Now the prototype adapter is almost finished. I can now connect the Nikon camera to the Pentax 645 lens system.
I have included a holder for 2 inch IR/UV cut filter, off-axis adapter.
Latest project page:
When skipping the Nikon bayonet I got a much bigger opening, now 46.5 mm, good for full frame sensors.
Lars
#4 Astrofriend
Astrofriend
Posted 05 August 2024 - 08:32 AM
Some more photos and information. The last is that I started to design the focus system:
Lars
  • giorgio_ne likes this
#5 Astrofriend
Astrofriend
Posted 15 August 2024 - 04:36 PM
More updates:
I have made 3D-printed brackets: focus driver, triple DC/DC box. The computer  can be a mini PC Windows or a Raspberry Pi5. Computer power by either  a 12/18 volt 3 Amp DC/DC converter or a 12/5 volt 5 Amp DC/DC. If my idea about a Nikon D800 camera don't work well for astro it's easy to convert to my old Canon 6D.
Details here:
The last thing I did was a 3D-printed dove tail and on top of that a main bracket that holds all the devices together.
Missing the stepper motor and a pivot bracket to it.
Lars
#6 Astrofriend
Astrofriend
Posted 28 August 2024 - 04:31 PM
Today I got the stepper motor that I will use for the focuser. Installed it today too.
Here is the latest, most pages with updated photos and text:
Now I can power up the Raspberry and do some test.
Lars
#7 Astrofriend
Astrofriend
Posted 03 September 2024 - 06:31 AM
Today I could do the first test to communicate with the Nikon camera. I started with the Windows system and used APT. It worked very well, none of the problem I have read about using a Nikon camera, maybe that bad reputation was for earlier models than mine.
Here is my documentation:
Lars
#8 Astrofriend
Astrofriend
Posted 08 September 2024 - 06:39 PM
First Light
Isn't it very exiting when testing a new device for the first time. This night I did my first test of the Nikon D800 and the Pentax 645 FA 300mm ED f/4 lens.
After some strugle I got an image, not very good because not all of the equipment is finished yet.
This is how it looks:
It look promissing to me. After this first test I had built a new motor focuser system, based on MyFocuserPro2. Almost exact the same design as my earlier one. It worked imediately after I power it up.
My biggest problem now is to get the ASI120 guide camera to work. This camera has some problem with Linux, I had it flashed with a new software, but still it doesn't work as it should.
Lars
  • whwang likes this
#9 Astrofriend
Astrofriend
Posted 13 September 2024 - 07:21 AM
A couples of nights ago we had a clear sky. I took some photos of the galaxy M81. That galaxy I have some photos from with my older equipment and I can now compare the two systems.
The Nikon D800 & Pentax 645 FA 300mm ED f/4
vs
Canon 6D & Pentax 645 300mm ED f/4
Of course not perfect control of the environment but still very exciting to compare them. That's important for me, which camera shall I spent the time with and which lens ? One of the cameras I will remove the filters from and the mirror as well.
Here is the first images to compare and some data I have collected about the cameras:
There isn't much difference, but I prefer the Nikon D800 with the Pentax FA lens.
Do you feel the same ?
Lars
#10 Astrofriend
Astrofriend
Posted 02 October 2024 - 08:47 AM
Every night there is a clear sky I take out my new equipment on the balcony. Take a lot of test photos, I'm on the go to build the tilt adapter, just waiting for some parts that I have ordered.
For you who curious how the the combination Nikon D800 and Pentax 645 FA 300mm f/4 ED perform I have som examples here:
http://www.astrofrie...en-cluster.html
http://www.astrofrie...ary-nebula.html
Look at the high resolution images. Even if there is some tilt I'm impressed. But to be honest, the older version of the Pentax 645 isn't bad either, the one without "FA" letters.
The of-axis guiding help a lot compare to the older guide telescope.
The Nikon camera has a lot of pixels. What's just a dot in center can be zoomed in and then you have something there. But it eating my hard drives in a fast pace.
Soon I will be out at a dark place and taking photos.
Lars
#11 Astrofriend
Astrofriend
Posted 08 October 2024 - 03:51 AM
Now I got the first surface mirror delivered. They are normally used in video projectors and then mass produced. They sell them cheap, 2 Euro each. I made an adaptor for the mirror that fit my off-axis adapter. The older one was made for a prism. The off-axis adapter is the new design I made and it has a tilt adjuster too. I was able to do some test to see if the guide camera receive any light. And yes it did, much brighter now with the bigger opening. But if I could move the mirror one mm closer to the optical axis it will be even better. The edges of the mirror protrude out in the light beam to the main camera. I have to grind down these edges in a 45 degree angle. I don't think that will be a big problem to do.
I took some new pictures of the equipment, look at the end of the page:
At the home observatory I works terrific, but out on the field I use the WIFI spot function. There is some wrong with the setup of the Raspberry. The WIFI transmitter looks to go down often and interrupt the connection. I read somewhere that the hardware can be setup in "g" mode, not "n" mode and then be much faster response. From the tablet to the Raspberry it's fast, but the answer is the one that is delayed, from seconds to minutes.
I will take a new look at the problem. It's setup in non sleep mode, something else that cause this.
This is what I have done to the WIFI spot setup (at bottom):
http://www.astrofrie...spberrypi5.html
Lars
  • photomagica likes this
#12 Astrofriend
Astrofriend
Posted 02 November 2024 - 02:03 PM
One more example of what the combination Nikon D800 and Pentax 645 FA 300 mm f/4 ED system can deliver.
http://www.astrofrie...a851-oam45.html
It's taken from a Bortle Class 9 environment. But the stars are sharp all the way to the corners. Look at the full resolution image and zoom in. The tilt adjuster is now working, it's a little fine adjustment left to do. A lot of try and error of the setup of KStars to control the Nikon D800 camera. Now it works like a dream. The guide camera ASI120 that I hade problem with in the beginning also do what it should do. The DIY MyFocuserProII also control the fokus motor with high precision, the tangent arm give much better result then the earlier tooth belt drive I had, less friction, less backlash.
Happy life ! Just need some darkness.
Lars
Also tagged with one or more of these keywords: 3d printing, DIY, DSLR
