So i actually fixed it last night as well The support person told me the firmware can't be updated via CFM and has to be updated via plugging into a PC via USB-C.
From there I was told to factory reset my SSAG through the hand controller. Last night completed a 3 start alignment perfectly.
Now I wasn't able to get it to center calibrate properly but I think that's a me issue and the sky portal app being not very intuitive. I still don't know if I'm supposed to hit allign or calibrate when trying to adjust to center position on a star.
Also you apparently can't use the hand controller once completing the alignment with the app. They don't communicate well. So I may just leave it unplugged.
I'm glad you got it to work! I have some thoughts ...
You can update the SSAG firmware via CFM or the web download. I have done it with CFM, and it showed that it updated.
I had tried a factory reset by holding down 0 on the HC and powering up the mount. Did you do something different? That reset did nothing for me.
After you do the align, do a GoTo to a star. Center the star. Press Align in Skyportal then press Calibrate. Then do another GoTo to check the calibration. Here's what happens with me. After doing a calibrate, then a GoTo to the same star I had centered on, the star will not be in the center. So I do another calibration. If, after the first calibration and GoTo, the star is above and left of center (I have an illuminated reticle EP) I move the star to below and right of center, then redo the calibration. Now when I do a GoTo the star is closer to the center.
Throughout the evening when I GoTo different parts of the sky I press Align in SkyPortal, then Align on the menu that comes up. That adds an alignment point. I am getting better results with the SSAG than with the SSAA, but I find that like with the SSAA, my GoTos improve by adding alignment reference points in different parts of the sky.
When I'm at the eyepiece I use the HC to slew the scope. It works fine and is easier than using SkyPortal because I can feel the keys and don't have to look at the HC. Just remember that if you align with SkyPortal your GoTos have to be done with SkyPortal and if you align with the HC your GoTos have to be done with the HC. But you can align with SkyPortal and manually slew with the HC.
That said, if you get a good alignment and calibration you will find you don't have to slew too much at all. The other night I was using a 10mm Ethos EP (.50° TFOV) and every target was in the FOV after a GoTo.
