Star Testing Round Two
The primary off axis aberration in refractors is typically astigmatism, which can develop quite quickly in fast APOs (don't believe me? Just look at any off axis spot diagrams....or mis-collimate your scope). I originally neglected to check the objective's collimation with the focuser using my Cheshire "eyepiece". After bringing the scope back in from outside, I did that after an hour of it sitting around. Sure enough, the reflection dots did not line up, the circles only half overlapping forming a sort of figure "8" pattern.
So, since this might be the source of mild astigmatism I'm seeing, I removed the dew shield (really easy) and found that the objective's cell assembly had three nice sets of push/pull collimation screws. Gently loosening up the three "pull" screws, and tweaking the push screws, I quickly had the reflection dots in the Cheshire all lined up. Securing everything and redoing the indoor star testing did indeed show an improvement with a residual 1/7 to 1/8 wave astigmatism.
I reassembled everything and took the scope out the next night, which had even better seeing. Using the same everything, yes there was an overall improvement from before with about 1/8 wave residual astigmatism. That's pretty good really, but then I had the idea of tweaking those collimation screw sets to perhaps dial out that residual. I've done that several times before with my achromat ATM projects, so why not here? I was using about 180X about 3-4 waves outside of focus when I removed the dew shield and then had a look to recenter Arcturus. And the astigmatism was gone. Really!? I went to ~300X. Still gone...but it started to slowly creep back in....then slowly leave. This went on for about a half an hour before settling back down to ~1/8 wave. I tweaked the collimation screws and indeed, I basically dialed it out to below 1/10 wave on average, which is below my personal level of detection. Just for fun, I slid the dew shield back on. No effect. Took it back off later....no effect. And as a bonus the HSA, or what I was calling HSA, was much reduced as well. The at focus images looked great, with no ambiguity at focus and with reduced color splashing too.
I redid the DPAC images the next day. Those are the ones shown above, with the PCT label, meaning Post Collimation Tweak. They are to me, identical to the originals shots I took, demonstrating the value of a quality star test to go along with DPAC testing. The Cheshire retest showed a mild misalignment of the reflection dots, which to me is further proof that the best optical axis may not be precisely normal to the objective's physical axis.
Subsequent lunar viewing has shown this objective to be very sharp indeed, giving that etched 4K HD look with the impression of vast detail, staying nice and sharp all the way up to ~220X before dimming took place. At low powers, color tint was quite neutral, almost clinical. Only with powers advancing above ~100X did I pick up a warmth to the image, especially with the excellent Denk II viewers I also used (which filter the blue to a degree) and especially combined with my Clave pairs....too warm for me actually.
To many, the moon is not a good test object for contrast as it's so high on the moon with the stark and intense shadows. However, I've also noticed it has many subtle color/tint contrast variations over the surface. This lunar color and contrast pallet was readily seen by me with this scope and very enjoyable.
This is a high fidelity objective. It's just too bad I'm too old and lazy to get up in the morning for the planets.
Now, eventually, I will compare this WO/TEC sample to my most excellent Orion 110ED F7 doublet sample and my SW120ED, both of which are very sharp visual scopes, maybe updating this thread later.
Jeff
