*** Dust, scratches, air bubbles, oil particles on optics ***
108 replies to this topic
#51 denis0007dl
denis0007dl
    Binoviewers Expert
  • Loc: Umag, Croatia, Europe
Posted 19 June 2024 - 08:34 AM
Here are some examples of my NEW prchased APO telescopes, with boxes unopened and had scratches....
#52 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 19 June 2024 - 08:35 AM
#53 denis0007dl
denis0007dl
    Binoviewers Expert
#54 denis0007dl
denis0007dl
    Binoviewers Expert
#55 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 19 June 2024 - 08:43 AM
Here is my LZOS 180mm APO lens...
#56 denis0007dl
denis0007dl
    Binoviewers Expert
...and...
#57 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 19 June 2024 - 08:45 AM
...example of chipped prism in binoviewers...
#58 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 19 June 2024 - 08:46 AM
...small chip lens edge on brandnew AP BARADV barlow...
Edited by denis0007dl, 19 June 2024 - 08:47 AM.
#59 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 19 June 2024 - 08:52 AM
...brandnew TeleVue BinoVue optical delamination in beamsplitter...
#60 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 19 June 2024 - 09:06 AM
ES 20mm 100 deg, brandnew, uncoated area...
#61 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 19 June 2024 - 09:12 AM
Brandnew arrival of APO SS binoviewers (not only one), with optical delaminations inside beamsplitter (can not be cleaned)...
#62 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 19 June 2024 - 09:13 AM
#63 denis0007dl
denis0007dl
    Binoviewers Expert
#64 denis0007dl
denis0007dl
    Binoviewers Expert
#65 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 19 June 2024 - 09:14 AM
#66 denis0007dl
denis0007dl
    Binoviewers Expert
Ok, now you have examples of everything how it looks like, and dont need to share more images, right? smile.gif
Kind regards,
Denis
  • Mike B, leonard, manolis and 4 others like this
#67 noisejammer
noisejammer
    Fish Slapper
  • Loc: The Uncanny Valley
Posted 19 June 2024 - 09:17 AM
I purpose an experiment. Someone take one of your clean eyepieces. Do some observing for a baseline. Now sprinkle a little flour (or your preferred dust proxy) onto it. How much “dust” until performance is noticeably diminished? Would be an interesting test.
Once upon a time, I had an urge to drag my home-made 6" f/8 Dob out for a play. I eyeballed Saturn but it was quite dim. Odd. I looked in the top and I couldn't see a reflection from the primary.
The scope had been sitting in the corner gathering dust. Quite efficiently, it turned out. I pulled the mirror cell and it was buried an eighth of an inch (3 mm) deep.
... And it still worked as a telescope. Just sayin'...
To return to the topic - cleanliness.
30+ years back I occasionally worked in a Class 100 clean room with Class 10 work stations. Getting in there was a performance - vacuum yourself, remove clothes, pull on bunny suit, climb over the barrier, walk to the next change room, vacuum yourself, remove bunny suit, climb over a barrier, walk to the next pressurised area, put on another clean bunny suit, hat, face mask, shoes, fasten all the velcro tape, vacuum yourself, put on gloves. Enter the pressurised area. Work.
So every time I entered the clean room it was at least two sets of gear and 10 minutes of preparation.
It sounds tedious but easy. It isn't. It's expensive and something you only do when it's absolutely crucial. I'd like perfect optics but I'd much rather pay for slightly imperfect toys.
  • Mike B, mountain monk, denis0007dl and 1 other like this
#68 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 19 June 2024 - 09:20 AM
P.S. oh sorry, just to add one diagonal example, brandnew Baader BBHS 2" mirror under angle...
  • leonard likes this
#69 Ihtegla Sar
Ihtegla Sar
  • Loc: Pacific Northwest
Posted 19 June 2024 - 10:10 AM
Oh, please. No one is suggesting optical companies should use a "class 100 clean room" and go through all that. They could eliminate 90% of the dust for less than 10% of the cost and hassle you are describing.
A set of fans and hepa filters to create positive pressure with clean air. Don hair net and wipe shoes on a mat before you enter. Simple and effective to eliminate most of the dust we are seeing on internal surfaces of eyepieces.
  • Mike B, manolis and TheChosen like this
#70 Starman1
Starman1
    Stargeezer
  • Loc: Los Angeles
Posted 19 June 2024 - 10:14 AM
...and...
That lens has fungus growing inside it.
#71 Starman1
Starman1
    Stargeezer
  • Loc: Los Angeles
Posted 19 June 2024 - 10:16 AM
Those are common, and caused by a dirt particle on the lens in the coating chamber.
  • Mike B, leonard and denis0007dl like this
#72 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 19 June 2024 - 10:35 AM
Zero fungus of any kind-checked extremly well!
#73 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 19 June 2024 - 10:36 AM
Edited by denis0007dl, 19 June 2024 - 10:36 AM.
#74 Mike B
Mike B
    Starstruck
  • Loc: My backyard in the Big Valley, CA
Posted 19 June 2024 - 11:00 AM
Kind regards,
Denis
  • leonard, manolis, dawnpatrol and 2 others like this
#75 Scott99
Scott99
  • Loc: New England
Posted 19 June 2024 - 11:08 AM
I've seen a few "figuring marks" or scratches on new lenses but nothing to the degree of the LZOS photo.
  • SandyHouTex likes this
