Hi all,
A friend who own a Celestron Evolution 8 alt-az mount asked for help. He used a solar Lunt telescope and the mount works well for many hours in the Sun at an astronomy festival.. Altitude motor has stopped working. At home, he opened the mount and change motors connectors on the mainboard. The other motor stopped working, so the driver failed just on one channel.
I've ordered the L293DD chip from a trusty supplier and replaced the bad one because I own a reworking SMD station.
After replacing the driver both motors worked for a while. I glued a small radiator on the L293 because it was hot when in use.
I didn't know how to use this kind of mounts, I tried it to bypass the alignment but failed. Just trying to move the alt and suddenly, the mount stopped entirely, including the hand controller. I've restarted it several times with no luck. With the main switch open the hand controller display an error message that it cannot connect, there is a tick sound and the LED blinks, also the HC display led blinks. With main switch closed nothing appeared on the display, just flickering. I tried different things to see what is wrong but nothing find.
I think the board is dead. It is replaceable? Can I order it from Celestron as a spare? I don't know how to troubleshoot it further, so please help me with suggestions what to do next.
Clear sky,
Tavi
