Sun Ha, June 23th, 2024 (mosaic 100MP)
Astrophotography Imaging Solar
2 replies to this topic
#1 lpalbou
lpalbou
  • Loc: Paris, France
Posted 23 June 2024 - 05:10 PM
I am falling behind in terms of processing as I generate about 1Tb of sequence / hour and for instance today, 4tb.
While processing those timelapses (today I normally got the M9 solar flare or AR3723 and I think I saw some good dynamics), I quickly processed a mosaic (Takahashi 76DC, Quark Chromosphere, Flattener 76d, Apollo M).
Enjoy !
Inverted contrast B&W:
2024 06 23 Mosaic BW 100MP
Colorized version:
2024 06 23 Mosaic 100MP
PS : if you have advice on how to better stitch together mosaic, I am all ear. For the moment, using photoshop / photomerge and trying to manually improve some junctions.
  • Illinois and Look at the sky 101 like this
#2 gstrumol
gstrumol
  • Loc: north of Detroit, Michigan USA
Posted 23 June 2024 - 05:24 PM
You might want to consider adding a normal view, so it would be easy to compare against GONG (it matches very well, BTW)
Doing so reveals some slight vertical banding, which may be due to building up the mosaic.
#3 IonClad
IonClad
  • Loc: USA
Posted 23 June 2024 - 06:21 PM
Have you tried PTGUI for stitching? It won't necessarily fix all the uniformity issues, but the blending is top-notch and it can try to adjust brightness at joins.
If you have a reference from a full-disk image (GONG or other) it may be possible to try and match the large-scale luminance of the higher-detail image to it. If done manually, perhaps use something like the difference blending in photoshop and adjust local areas to match the reference full disk image.
Also tagged with one or more of these keywords: Astrophotography, Imaging, Solar
