My Orion Atlas mount is a twin brother of your mount. The power connector is a 5.5x2.1 barrel connector. The female port on all of these mounts will eventually fail unless you affix the power cord to the body of the mount to prevent it placing lateral stress on the mount's port. My solution to this issue was to purchase a small package of "decorator velcro" from a local store. The sticky side was attached to the mount while the non-sticky side was cut a bit longer than the sticky side so that when the ends of the strips are aligned, there's a small loop in the middle. A full wrap of the power cord through this loop then plugging the barrel connector into the mount will have all of the stress managed by the velcro and the mount's port should last at least your lifetime.
Grr... I got a 12V 5A DC Power Supply with 5.5x2.1mm Plug but the 'Power " light will not light up. Moving to plan B - Getting 8 C batteries to see if the motor will at least power up.... Thanks for every one's thoughts and ideas - I appreciate it.
UPDATE - A ID10T error - Ya have to plug the hand controller in properly for the unit to 'power-up'. I think I'm in business. We'll see how the mount tracks.
Edited by Spoelker, 28 June 2024 - 03:54 PM.
