I'm looking for a higher power eyepiece for my finder scope that offers roughly a 4.2 degree field of view, enough eye relief for wearing glasses, relatively light weight, and might be able to handle an F/3.75 light cone in a short achromat.
A contender is the 16mm Orion EF / 16mm BST Flat Field / 16mm Angeleyes / 16mm Lunt Solar Flat Field / 16mm TS Optics Flat Field. Near as I can tell, these are all the same eyepiece. However, the specifications are all over the map and I don't know what to believe.
16mm Orion EF: https://www.telescop...ce/p/130565.uts
- Apparent field: 65 degrees
- Field stop: unlisted
- Eye relief: 18mm
- Weight: 5 oz
- Elements: 6
16mm BST Flat Field: https://agenaastro.c...d-eyepiece.html
- Field stop: 16.5mm
- Eye relief: 19mm
- Weight: 3.5 oz
- Elements: 6
16mm Lunt Solar Flat Field: https://www.highpoin...yepiece-ls12e-1
- Apparent Field: 60 degrees
- Eye relief: 15mm
- Weight: 3.7 oz
- Elements: 5
16mm TS Optics Flat Field: https://www.astrosho...m-1-25-/p,63397
- Field stop: 20mm
- Eye relief: 15mm
- Weight: 4.2 oz
- Elements: 6
16mm Omegon Flat Field: https://www.omegon.e...#specifications
- Eye relief: 9mm (
- Weight: unlisted
- Elements: "5 or 6"
16mm Angeleyes SWA: https://www.aliexpre...2825898530.html
- Apparent field: 70 + 72 degrees
- Field stop: 16.5mm ??? (listed as "distance of exit pupil" if we are to believe the 16.5mm figure from the BST Flat Field above)
- Eye relief: unlisted (unless this really is "distance of exit pupil")
- Weight: unlisted
- Elements: 6
16mm Alstar Premium Flat Field: https://www.amazon.c...s/dp/B0748FN1TN
- No useful information listed. Just lists the range of specs for the whole line.
Chaos. None of these agree with each other. Are there different versions of this eyepiece or something?
Edited by CrazyPanda, 24 June 2024 - 08:06 PM.
