The Veil Nebula in Cygnus is now rising above the trees in my backyard before 10 pm, and I succesfully imaged the Western Veil (NGC6960) with 7.5 hours of OSC data recently with my AT115EDT and my ASI2600MC (see below - a higher resolution version is posted in my gallery). I have used my 51mm Redcat for a wider field image of the entire Veil in the past, and am considering using the AT115EDT with a Starizona ED-L reducer ( 530mm fl ) to capture a 4 pane mosaic of the Veil to get a higher resolution and higher quality image that will stand up to enlargement. I am hoping a mosaic with the faster imaging with the larger refractor will produce a better result. I tried this with M31 last fall and it yielded a good result. Does this make sense? Any advice if I go forward? Thanks.
