Finally I decided to buy the Baader 8-24 Zoom. The field is smaller than the Delos (apparently between 45 and 65°) depending on the focal length. Coupled with the NV which has 40°, the field is enough.
Optically it looks very good to me. It does better using a Paracorr. It is necessary to play a bit with the focus of the NV: I found out that it is better to focus the NV on the very short distance (then you focus with the telescope). This way the Baader is almost perfectly parfocal and the corrected field is great. Whereas if you set NV to infinity and focus with the telescope, there is some vignetting, it is not parfocal and has astigmatism at the edges.
Zooming allows you to change magnification on the fly. Changing eyepieces by moving the NV is cumbersome and wastes a lot of observing time. The most commonly used focal lengths are 20 to 12 mm. Between 12 and 8 there are internal reflections that are not seen visually but only with NV. Anti-reflection treatments are obviously optimized for visual, and these reflections may originate in the infrared. If I really want to get the optimum between 12 and 8 mm, I use the 9 mm ES. Otherwise the image quality (with NV mounted) is identical to that of regular eyepieces.
High magnification, between 12 and 8 mm: I have seen they are very useful for seeing inside small planetary nebulae. Last night I resolved Cat's eye NGC 6543 by observing the central star and several inner lobed structures. More difficult was NGC 6210 which is smaller, but again there was a hint of internal structure. For comparison, with the 60 cm dobson it is difficult to see internal structure on these small planetaries, because of the size and the high contrast with the sky background (the same reason that you see details on Ganymede when projecting onto Jupiter, but not when projecting onto the sky background).
Globulars: the more you zoom in the more resolved they become, down to about 12 mm. M13 and M92 were perfectly resolved in stars (I dare say as in 60 cm). SQM 18.5.
Galaxies also seems to like somewhat high magnification, Say around 16 mm. The Spindle Galaxy, M102, was visible against a SQM 18.5 sky, albeit no details were resolved.
Another thing is nebulae that require filters. Even just a UHC-S makes one prefer magnifications around 24 mm (52x) or, better, the Pentax 40. But that is another story and, fortunately, there are not only emission nebulae.
I look forward to trying it out under a dark sky.
Translated with DeepL.com (free version) and minimally re-edited.
Edited by Mauro Da Lio, 28 June 2024 - 02:34 AM.
