An excellent choice for visual and EAA.
For visual, with the Edge HD focal reducer it will fully illuminate any 2" eyepiece. This means that unlike a normal C11 you can enjoy an about 60x 1.3° FOV with a 31mm 82° eyepiece. The ample 11" aperture allows for solid nebula viewing using narrower filters like OIII or Hb. The long focal length also means comfortable planetary viewing at high magnifications. Even with the reducer in place, a 10mm eyepiece allows for about 200x at 1.4mm exit pupil. For that really still night, a 7mm eyepiece yields 280x at 1mm exit pupil. You also have ample aperture for binoviewing if you choose to jump down that rabbit hole. Without the reducer, using a pair of 15mm eyepieces and a Celestron binoviewer, I I've seen Jupiter in a way that I've only seen in NASA images from my backyard.
For EAA and imaging, matching a camera to the scope's massive focal length is a challenge. The Edge HD focal reducer gets you down to 1960mm and paired with an ASI294MC you're at 0.5"/px. Good for galaxies, but a limited FOV. I originally messed with Hyperstar, but found that it made fine details too muddy. I've been thinking about adding a cheap 2" 0.5x focal reducer behind the Edge HD reducer to bring the overall focal length to about 980mm. There's also the hope that the Starizona NightOwl HD reducer is anything more than vaporware, but I wouldn't count on it. I'm really curious about the Pegasus Astro SmartEye, though the IMX533 sensor will need hefty reduction as well for any useful FOV.
The two downsides are weight and difficulty placing on the tripod. Weight can be mitigated by getting a wagon to drag the OTA and Mount around (about 70 lbs). For placing on the tripod, I strongly recommend the Starizona Landing Pad. It helps you center the mount on the tripod. Without it, it's somewhat precarious until you get the pin in the receiver on the bottom of the mount. I also strongly recommend the Celestron dew shield. It's somewhat heavy and expensive, but much better than any foldable dew shield I found. It also neatly counterbalances the focal reducer and 2" diagonal.
